Old 04-19-2016, 07:40 AM   #1
07travis
07travis's Avatar
Headlight dimmer switch wiring help!?
I've been in the process of rewiring my 72 to get it on the road again this summer but it seems like every time I look, I find another burned wire.... The current problem I am fixing is the headlight dimmer switch. As you can see by the picture, someone's replaced the switch before and did a real good job wiring it... They went so far as to tape it up with masking tape to make sure there wouldn't be any issues!!! What I need help with from you guys is what color wire goes to which post on the switch? I have a new switch and connector, but the connector only has black wires. The switch that was there is obviously wired, but I want to make sure that the right wire is going to the post before I wire it in. Any help is greatly appreciated!! Thanks!
07travis is offline   Reply With Quote
