04-19-2016, 09:22 AM | #1 |
Don't blame the messenger
Custom Seat - Install 2010 Dodge Ram Seat
I have been asked to post how I modified these 2010 Dodge Ram Seats to fit my 69 C-10. Hopefully this will help someone out there. I picked the seats up from the local pick a part. $35 for the set, the covers were trashed. Neglected to take before pics, wish now I would have. The seats had head rests which I removed while recovering them. I purchased the leather hide from Kyson Leather- Labeled as Modern Black. It had the flat black sheen I was searching for. Patterned the flames off the valve covers and transferred the pattern to the leather. Hand stitched the flame pattern on to 1/2" sew foam. The center console lid was done with a foam overlay. This is the result after about 30 hrs.
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." |
04-19-2016, 09:32 AM | #2 |
Re: Custom Seat - Install 2010 Dodge Ram Seat
Seat Frame Modification:
I utilized the factory seat mounting locations already on the floor board. To do this, I cut off the dodge seat mounting tabs and placed the frame work in the truck. I used 2" flat bar to span between the adjustment rails of the frame. Measured and cut the flat bar, then located the mounting holes on the floor board, marked the flat bar and pre-drilled the hole. Bolted the flat bar to the floor and lined the frame work to the flat bar. I did this for both sides, aligned everything and then welded the flat bar to the seat frame with everything in place.
04-19-2016, 09:39 AM | #3 |
The actual frame modification took just a few hours to do. Here is the mounted results.
04-19-2016, 09:42 AM | #4 |
That looks as good as BuddyBuckets and probably sits better ,very nice seats and your custom upholstery is killer.
04-19-2016, 09:51 AM | #5 |
I think they are a comfortable alternative. Thanks for the compliment.
04-19-2016, 10:09 AM | #6 |
How much do a set of those run?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-19-2016, 10:49 AM | #7 |
these look really REALLY good
04-19-2016, 10:58 AM | #8 |
Nice... they look right at home in there. I like them A LOT. Does the console have the 12V power source and MP3 outlets inside?
POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
04-19-2016, 11:01 AM | #9 |
I have the same seats, pm me the cost for a set of covers minus the flame stitching. Thank you.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
04-19-2016, 11:05 AM | #10 |
Wow! Your seats turned out excellent.
Scott |
04-19-2016, 11:37 AM | #11 | |
Seats cost $35. Upholstery materials about $400.
Sorry, I'm not looking for projects.
04-19-2016, 01:33 PM | #12 |
Those look amazing! Excellent work! I have two questions for you. Is the seat cushion roughly the same height from the floor as original seats? (Is the ride height the same) and did you have to cut down the backrest to get it below the window?
Thanks! |
04-19-2016, 02:38 PM | #13 |
Definitely better than spending 500 plus bucks factory buddy buckets!!
04-19-2016, 02:42 PM | #14 |
Awesome!
04-19-2016, 03:14 PM | #15 |
Looks like you ditched the plastic cover pieces on the side as well.
04-19-2016, 03:32 PM | #16 | ||
2. That's what I love about this seat. I didn't have to make any major modifications. I only removed the head rest and filled the holes. Quote:
Actually no, this model seat did not have the plastic but rather a cardboard covered curtain that hides the tracks. (I should add that I intentionally chose this seat because of simplicity, no electronics or controls that I didn't need) I do plan to fabricate something to conceal the tracks- but that will be down the road during finishing.
On the Level Just a guy with a hammer and a grinder. OH!, and an HOA- enough said...: http://67-72chevytrucks.com/vboard/s...d.php?t=372525 "Some drink from the fountain of knowledge while others just gargle." Last edited by Hellbent; 04-19-2016 at 03:38 PM. |
04-19-2016, 05:49 PM | #17 |
Nice, I love the storage too. You get the armrest with storage and you can lift it for a center seat. Does the center seat lift for more storage too. The last two Rams I owned you could lift the center seat for storage also.
Tempting to get rid of the bench. But my junkie old bench is surprisingly comfortable. I put new upholstery on top of old junk springs and stuffing. Comfortable believe it or not. But those look real nice!
White K20 |
04-19-2016, 06:01 PM | #18 | |
04-19-2016, 06:37 PM | #19 |
Does the center seat have a seatbelt as well? Does the center belt attach to the frame or the cab floor?
Thanks. |
04-19-2016, 08:41 PM | #20 | |
I'm actually in the middle of designing a way to secure those belt points from the frame of the seat to the floor board. Just for peace of mind.
04-20-2016, 07:57 AM | #21 |
Custom dash, suicide doors, this truck is going to be amazing! Show us more pics when you can!
04-20-2016, 08:27 AM | #22 |
I just read your entire build thread, you do excellent work! I have never met anyone who was good at upholstery and welding!
04-20-2016, 06:37 PM | #23 |
Hey Thanks Steve-
04-20-2016, 08:44 PM | #24 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-22-2016, 02:12 AM | #25 |
Thank you vet much awesome work and great write up, really appreciate the time you put into showing us your work and skills.
