Old 09-27-2003, 04:46 PM   #1
bigd65
bigd65's Avatar
4 headlight system
ok a while back i did the 91 burb grill conversion and now i want all 4 headlights to burn on bright. i need the wiring diagram that someone had posted on here in the past about it. now that i dont have the electric fans, i am going to use the relay from that system. it is actually the same as the one someone had before before. thanx in advance for your help
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-27-2003, 08:25 PM   #2
kevhill85
91 SWB 383
kevhill85's Avatar
i just add a relay to mine . how close r u to greenville tx . i can help u there.
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 09-28-2003, 08:07 AM   #3
bigd65
bigd65's Avatar
well im 40 south of HOUSTON. i have the relay, i just need the wiring diagram for it
2017 Chevy Tahoe
Old 09-28-2003, 11:41 AM   #4
kevhill85
91 SWB 383
kevhill85's Avatar
i don't have it . i'll tey to make one today . i did it by testing wire . i'll give u an idea of what to do .
Old 09-29-2003, 03:47 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
This not the one I posted a while back but it works. This one requires two relays which not bad so each light is protected. However you can convert it to use only one.
http://www.humanspeakers.com/audi/headlight-simple.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-29-2003, 04:02 AM   #6
gchemist
gchemist's Avatar
http://www.rowand.net/Shop/images/He...ingDiagram.jpg
Old 09-29-2003, 08:41 PM   #7
bigd65
bigd65's Avatar
thanx G, i think i can read this one.
i guess i can wire one relay to both head lights right and not be to much for the relay. i already have the trigger wire from the old 4 head light system. it just wont work with the 91 brill set up. if i hook them up without a relay, when i turn on the hi-beams they will come on but the hi-beams wont go off. so i figure if wire in this relay, it ought to work right . RIGHT?
2017 Chevy Tahoe
Old 10-02-2003, 05:49 PM   #8
bigd65
bigd65's Avatar
HEY G< thanx alot, that worked great. i just completed it
2017 Chevy Tahoe
