Old 04-19-2016, 01:07 PM   #1
BIGglaSS
BIGglaSS's Avatar
Door hinge rebuild 1955-1959
I'm rebuilding some door hinges. This is the kit I have. Question.. Which bushings do I use? The knurled ones or the bronze ones, or both? Do I need to remove the steel sleeve that is in the old hinge, or simply drill it so I can press in the new bushings? The knurled bushing is .488" and the bronze bushing is .420". I feel like it is kind of a dumb question, but it looks like the kit has more bushings than is needed. Thanks.
BIGglaSS is offline   Reply With Quote
Old 04-19-2016, 02:13 PM   #2
BIGglaSS
BIGglaSS's Avatar
Re: Door hinge rebuild 1955-1959
Is there an easy way to remove/repair the square weld nut on the back side of these hinges? This one is rusted and will not remove. Spent about a half hour trying to grab it with vice grips. Help... Before I do something crazy like cut open the door skin on the other side!
Old 04-19-2016, 07:39 PM   #3
BIGglaSS
BIGglaSS's Avatar
I finally got the vice grips on the weld nut. With some heat, I got that bolt out. Now trying to figure out a way to weld a new nut back in.
Old 04-19-2016, 09:12 PM   #4
mphudak
Wild guess, but do the knurled ones go in the part that bolts to the cab and the bronze ones on the hinge section that bolts to the door?
How bad of condition is the area where the bolt snapped? Can you use a rivet nut?
55.1 GMC Suburban Hydramatic
mphudak is offline   Reply With Quote
Old 04-19-2016, 10:59 PM   #5
ndeep
Looks like you have the wrong bushings. the old one can be drilled or driven out and the new one can be pressed in, i use a bench vice. back in the day we used the knurled ones to repair hinges that had worn excessively (hole egged). As to your hinge pocket problem you just need to remove the pocket by drilling out the spot welds,repair the pocket and reinstall. Sounds easy if you say it real fast,actually not that bad of a job
ndeep is offline   Reply With Quote
Old 04-20-2016, 02:03 AM   #6
MARTINSR
MARTINSR's Avatar
Here is a "Basics of Basic" on rebuilding hinges that may be of help. http://www.hotrodders.com/forum/basi...es-125350.html
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-21-2016, 01:09 AM   #7
BIGglaSS
BIGglaSS's Avatar
Got it figured out. The old ones were nylon. The smooth ones tap right in, no drilling needed. I think ndeep is right, the knurled ones are for excessive wear.
Old 04-21-2016, 04:38 AM   #8
tmoble
I'm doing mine now also. My truck is a West Coast built 57, has the plastic bushings. 7 of the 8 were still there, drivers side lower was gone.
tmoble is offline   Reply With Quote
Old 04-21-2016, 05:08 PM   #9
dsraven
those weld nuts are accessible from the front side, are they not? take a fender off and you have access?
Old 04-21-2016, 05:28 PM   #10
Knothead
Knothead's Avatar
There is a part to replace the whole box the hinge bolts to. It requires drilling out spot welds and welding in new piece in the door. Don't remember which vendor carried them ?
Knothead is offline   Reply With Quote
Old 04-22-2016, 01:20 AM   #11
dsraven
sorry about my previous post, I was thinking you meant the door post area. knothead is right, the pocket rusts or cracks and then the door flexes so you can never get it to fit the same after shutting it twice in a row. also check the little web of metal between the inside and outside panels in the area at the bottom rear of the vent window. they crack there and allow flex as well. there is a youtube on repairing the lower hinge pocket on the door.
