Old 04-19-2016, 01:37 PM   #1
Nodnarb76
Nodnarb76's Avatar
MAF mounted to throttle body. Problems?
Still in the middle of my LS swap.
One thing that has come up is my air intake. Using the Sadden A/C compressor and Dirty Dingo A/C brackets, does not leave a lot of room for the air intake. I bought a Spectre intake that puts the filter right where my battery currently sits. I could relocate the battery but that would be a hassle as I already have my PCM mounted in that corner.
My current plan is to cut about 5" off the intake pipe and see if that gives me enough room to mount the filter and still close the hood without it touching the A/C compressor. If all else fails. Was thinking of just mounting a filter to the throttle body. Could I do this and mount the MAF sensor between the filter and throttle body? I heard GM likes these to be further away from the throttle body, but I may not have a choice.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 04-19-2016, 02:39 PM   #2
Kainedogg
Kainedogg's Avatar
Re: MAF mounted to throttle body. Problems?
"Was thinking of just mounting a filter to the throttle body. Could I do this and mount the MAF sensor between the filter and throttle body?"
That is what I did initially for my C10...until the 4l80e forced me to bring the engine forward more than I wanted. It should not be a problem.
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
Old 04-19-2016, 03:06 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
I'm not sure of the locations of your stuff and I'm assumimg you have a spectre cold air but this is how I did mine using spectre parts..I just bought a aluminum tube off ebay and cut it to fit...I've had no issues with where the maf is. Its about 2 " from the throttle.
Old 04-19-2016, 03:59 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Technically speaking, putting the MAF on the TB puts it at a point of potentially turbulent air, and doesn't fit within the GM/Delphi recommendations for installation. On most "squishy" tunes (i.e tunes with plenty of safe-room, not max effort jagged-edge builds), the MAF and 02's will be able to dial out some of the negative effects. You run a slight risk of stalling on situations in which the throttle goes from full open to snap shut, because of the rapid change in air volume around the tb as it snaps shut.
Or you can also change to SD tuning and ditch the MAF (or use it as a glorified temp sensor).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-20-2016, 02:29 PM   #5
Hart_Rod
Hart_Rod's Avatar
To piggy back on what Brew said, if your MAF is a dual IAT sensor, getting it further away from the engine will help reduce the sensor "heat soak" and give more accurate readings to the ECM.
With that being said, lots of LS conversions run the setup you are talking about with minimal problem.
more info here: http://ls1tech.com/forums/pcm-diagno...elocation.html
Hart_Rod is offline   Reply With Quote
