Old 04-19-2016, 01:56 PM   #1
Goldengophersax56
Goldengophersax56's Avatar
Painting a Radiator
Hey guys,
I just had my radiator for my '56 GMC boiled out and pressure tested. The shop said it's in really good shape. The radiator is the stock GMC radiator and it will be running a SBC 350.
At this point now it needs to get painted. What tips do you guys have for painting it and what suggestions for product do you have. There are a couple small dents in the top of the tank that would be nice to fill if I could. Ideally, if I could use engine primer and paint, I'd like to do that so that it matches (it is VHT Metallic Black). Obviously, if that will mess it up, I'll switch to something else if I have to.
Thanks!
Dan
P.S. I accidentally posted this in the "Projects and Builds" section so if there is a moderator or someone who can remove it, I would appreciate it.
Goldengophersax56 is offline   Reply With Quote
Old 04-19-2016, 02:00 PM   #2
_Ogre
_Ogre's Avatar
Re: Painting a Radiator
i wouldn't suggest any filler on the tanks, it will fail
paint the tanks only, paint on the fins will make heat transfer less and may cause overheating
shop air compressor timer
Old 04-20-2016, 09:58 AM   #3
Goldengophersax56
Thanks for the feedback Ogre! I just need to look into something then to clean up the fins a bit then. Some of them have a bit of oxidation on them. I read a toothbrush (gentle on the fins) and some vinegar helps.
At any rate, Thanks!
Old 04-20-2016, 11:55 AM   #4
Wrenchbender Ret
My radiator shop says to use lacquer paint on the radiator tank & fins. Ive used body filler on top tanks & had good results. One time I had a thin crack in one.
Wrenchbender Ret is offline   Reply With Quote
Old 04-20-2016, 12:50 PM   #5
OrrieG
OrrieG's Avatar
rattle can engine paint, Duplicolor 1634 black is my favorite not to glossy and matches most OEM black finishes. High temp paint that will handle the heat.
OrrieG is offline   Reply With Quote
Old 04-20-2016, 05:57 PM   #6
1project2many
Old time treatment was lamp black or stove black plus gasoline or turpentine. Enamel paint was next. Latex is common today.
http://www.northernfactory.com/UserF...es/STOCKUP.pdf
1project2many is offline   Reply With Quote
Old 04-21-2016, 05:06 PM   #7
dsraven
just enough paint to make it look black. too much will inhibit heat transfer. some say black transfers heat better. I dunno.
Old 04-21-2016, 11:27 PM   #8
57chevyman
57chevyman's Avatar
i painted my radiator, fins and all with black gloss rustoleum spray paint three years ago. didnt affect performance of radiator. i just put a light coat on the fins.., just enough to make it look nice.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
