Old 04-19-2016, 02:47 PM   #1
79Heavychevy
K10 rear brakes
Hello everyone........new to this forum stuff but here goes.
I have a 1979 k10 series chevy pick-up 4x4
with 1-inch inside diameter rear wheel cylinders.
The rear end did not come with rear brakes or drums.
Which size rear brakes and drums do I need to order.
I know there are two choices but have no idea which to pick.
Any help would be great.
79Heavychevy is offline   Reply With Quote
Old 04-19-2016, 08:43 PM   #2
Front Range
Front Range's Avatar
Re: K10 rear brakes
If your looking at 2 drum sizes which drum sizes are you looking at? Which rear axle are you running - assuming it came with a rear axle.
79 K10 rear brake drums should probably be 11-5/32 x 2-3/4 and the wheel cylinders 15/16ths.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 04-26-2016, 04:16 PM   #3
79Heavychevy
Re: K10 rear brakes
Found a great resource at this website
tells you everything about dimensions of everything on certain GM vehicles...
Check it out......go to the archive section for vehicle information kits.
ITS FREE....
www.gmheritagecenter.com
Old 04-27-2016, 01:28 AM   #4
El Dorado Jim
Re: K10 rear brakes
welcome to the site!, sorry can't help you , I have 3/4 tons only
El Dorado Jim is offline   Reply With Quote
