Old 04-19-2016, 04:18 PM   #1
badherb
badherb's Avatar
Cool Info needed the po didn't give me
1960 swb. The front end was replaced with I assume 73up truck front-end. The ball joints are riveted in place. What years had this style ball joints? Plus the power steering box was mounted but I don't know specifics on it so I can replace hoses and buy steering shaft rag joint etc. Any help is appreciated.
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 04-19-2016, 04:26 PM   #2
urmyboyblue
Re: Info needed the po didn't give me
I would assume that if the front end is out of a 73, that any year model from 73-87 would have the same ball joint. The hoses went metric at some time in those years I believe. The best thing to do is to look at the hoses when you pull them off. I think that the metric ones had a blue tint to the coating on the nuts. I am sure someone that has worked on these more recently than I have will chime in.
urmyboyblue is offline   Reply With Quote
Old 04-19-2016, 05:54 PM   #3
badherb
badherb's Avatar
Interesting! never thought metric would have happened in that era.... so i checked and sure enough fasteners on the front end seem to be metric. checked three different fasteners and they are all metric. and the steering box does not have anything to check that but assuming the PO got everything from the same truck.
ANYONE ELSE?
1960 SWB “Pops”
Old 04-19-2016, 06:06 PM   #4
PGSigns
PGSigns's Avatar
If you can post some pictures of the setup in your truck it will help refine the information you will get.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-19-2016, 06:15 PM   #5
62jimmy
If its a metric frontend I believe that would narrow it to an 84-87 frontend. I just went through ordering all the necessary moog replacement parts to completely rebuild a frontend I was told was an 84. The only difference I found in part numbers was the pitman arm changing after 83. I ended up needing the pre-84 pitman arm, so I may have been told the wrong year. Everything else carried the same part numbers (balljoints, tierods, adjusting sleeves, idler arm, control arm bushings) from what I remember from 73-87
62jimmy is offline   Reply With Quote
Old 04-20-2016, 01:45 AM   #6
badherb
badherb's Avatar
Were your ball joints rivited in?
1960 SWB “Pops”
Old 04-20-2016, 10:03 AM   #7
60chevyjim
60chevyjim's Avatar
I think all ball joints are riveted from the factory .
my 65 and the 79 crossmember I have for it both have riveted ball joints so if there bolted in then they were replaced.
to get a idea what year your steering box is .
take a hose loose from the steering box and see if it has a flare fitting on the end
or the newer Oring setup on the line .
this will let you know about what year the box is ..
>>> up to 1979 has the flare fitting >> 1980 started using Oring fittings on the lines
60chevyjim is offline   Reply With Quote
Old 04-20-2016, 10:11 AM   #8
62jimmy
Yes, mine were riveted, I think 60chevyjim is right, they are riveted at the factory, replacements are bolt in. Also, it was the idler arm that was different, and I had to exchange for the pre 84 part not the pitman arm, had a brain lapse
Old 04-20-2016, 01:29 PM   #9
badherb
badherb's Avatar
top side of upper a arm
1960 SWB “Pops”
Old 04-20-2016, 01:30 PM   #10
badherb
badherb's Avatar
the hard lines left on the box are 1 cut on the pressure side 2 a barb (bubble) in the line to hold a hose from sliding off.
1960 SWB “Pops”
Old 04-20-2016, 01:46 PM   #11
badherb
badherb's Avatar
here is a photo of the drivers side and the steering box
1960 SWB “Pops”
Old 04-20-2016, 02:07 PM   #12
badherb
badherb's Avatar
Steering box has a raised id number of 7812145 no definite answers for the box but it could be a saginaw box 68-77 year. I'll look for more stamping on the box.
1960 SWB “Pops”
Old 04-20-2016, 02:34 PM   #13
badherb
badherb's Avatar
7802644 is the other casting number and I have narrowed it down but still nothing definite. most of the hits Im getting are on this site. heh
1960 SWB “Pops”
Old 04-20-2016, 03:25 PM   #14
60chevyjim
60chevyjim's Avatar
you need to unbolt either one of the lines from the steering box and look at to end of the line that goes into the steering box.
it will be a flare or it will use a Oring
79 and older use a flare fitting...
1980 and newer use the Oring style fitting .
Old 04-20-2016, 04:40 PM   #15
PGSigns
PGSigns's Avatar
Also pull a wheel and see what the thickness is. Light duty is 1" and heavy is 1 1/4" that way if you go to order spindles or brake parts you will need this info. Also looks like you are missing a frame cross member.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-20-2016, 05:16 PM   #16
badherb
badherb's Avatar
Jimmy
What is 1" or 1 1/4"? Is it possible for you to show me the cross members missing part?
The steering box has double flare end.
Thanks guys!!
1960 SWB “Pops”
Old 04-20-2016, 05:21 PM   #17
badherb
badherb's Avatar
7812145 and 7802644 on steering box
1960 SWB “Pops”
Old 04-20-2016, 06:03 PM   #18
PGSigns
PGSigns's Avatar
The rotors come in two thicknesses so pull the wheel and measure how thick they are. I also don't see where it was drilled for the later model idler arm. Forgot this is a 60 it does not have the crossmember for the radiator like the 63 and up.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-20-2016, 06:11 PM   #19
badherb
badherb's Avatar
the idler arm is on passenger side. Saw a 68 in teh junk yard the front end was the same as mine even had the sway bar still. only difference was the 68 had grease serts on all bushings.
1960 SWB “Pops”
