obd2 connector help
guys i have a 55 with a 5.3 from a 06 truck and computer from 02 camero ,, all has been great , i have loaded tunes and played with it tons ,, i did a push button start and now i cant load a tune, it says cant connect and to check connection ,, i can scan and do log runs , so i think i am linking up to ecm ??
i have 4 wires purple = data black = ground = chassis blk/wht = ground = signal orange = battery the ground check out i check with ohms all good , the orange is 12 volts hot all the time ,, how do i check the data port ? i dont understand nothing changes when i go in to acc mode . or what is suppose to happen that mode thanks |
#2 | |
![]() Join Date: Apr 2005
Re: obd2 connector help
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
no i am not ,, right now the 4 fuses under the hood that came with the harness are dead in the acc mode ,, now after i start they are hot ,, i am able to read and scan the ecm after its running
i have a acc wire messed up somewhere thanks |
all good wiring issue with my push button ,,,, now i need to figure out shifting in the tune
thanks |
