Old 04-20-2016, 07:57 AM   #1
Lanman1972
Lanman1972's Avatar
WTB: 1971 Cheyenne 2WD 350 Parts
Pair of Exhaust Manifolds for 350
Heat Riser tube assembly from manifold to Air Cleaner.
Good Passenger Fender Cup, cut above Body Line
Power Brake Booster, M/C, Prop Valve, Bracket and Rod.
A/C Compressor and Bracket for 350.
U-Bolts for Rear end to Trailing Arm. 2wd.
Battery tray w/ A/C
Please post pics or PM and I will respond. Thank you
Lanman1972 is offline   Reply With Quote
Old 04-21-2016, 08:01 AM   #2
Lanman1972
Lanman1972's Avatar
Re: WTB: 1971 Cheyenne 2WD 350 Parts
ttt
Old 04-21-2016, 09:35 AM   #3
1rippen6
I have a brake assembly but is for a 4x4 I don't know if they are the same.
1rippen6 is offline   Reply With Quote
Old 04-21-2016, 09:44 AM   #4
Lanman1972
Lanman1972's Avatar
Thanks, maybe someone will chime in. I'll do some looking too, thanks
Old 04-21-2016, 10:21 AM   #5
John H.
John H.'s Avatar
Brake booster setup is the same as long as it is a 71-72 system for disc front end. Hardlines are different from prop valve down.
John H. is offline   Reply With Quote
Old 04-22-2016, 06:27 AM   #6
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have a set of 350 manifolds, came off of a 72 C-10. And I have a proportioning valve off the same truck, disc front, drum rear. $200 for all three, come on down, I also have a right fender but the bottom of the cup is rusted. I have a riser tube in good shape as well...I'll get pics of the riser and fender today...~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-22-2016, 08:48 AM   #7
MidLifer
MidLifer's Avatar
I have a booster that I just pulled from my truck for a hydroboost swap. I'll take $25 + ride. The brown truck guys say it would cost $15 to ship to Omaha from Joisey.
MidLifer is offline   Reply With Quote
Old 04-22-2016, 03:58 PM   #8
Lanman1972
Lanman1972's Avatar
Thanks ghostrider, do you have the booster or just the prop valve? I have a real good fender except for the cup.
Old 04-23-2016, 08:08 PM   #9
Lanman1972
Lanman1972's Avatar
I now have the ubolts, still need the other items.
Old 04-25-2016, 03:08 AM   #10
Ironangel
Ironangel's Avatar
Just the prop valve w/bracket. I have the heat riser tubes as well. let me know and I'll post some pics. I have a couple of charcoal canisters as well, all parts off of 72 C-10's...I got tied up this weekend and wasn't able to get those pics, I'll get that first thing in the morning.
"Two Seventy Two's"
02 3/4 ton Express
Old 04-25-2016, 02:00 PM   #11
Ironangel
Ironangel's Avatar
Give me a call, I PM'd my number...
"Two Seventy Two's"
02 3/4 ton Express
