Old 04-20-2016, 03:17 PM   #1
LDO
LDO's Avatar
Another Tire and Wheel Thread But Please Read!!
Folks,
please don't hate me!
I believe I have read every rally wheel and tire selection thread on here.
My 1985 has 7" rallies. I was planning on going with 255/60-15 front and 275/60-15 like several members here have but they've used 8" rallies.
My truck will have a 4/6 drop. 2.5 spindles and drop springs, rear flip kit.
Does anyone have pics of what those tires will look like on 7" wheels? The tire rack website says they will work but it would be great to see what it will actually look like.
Thank you in advance.
LDO is offline   Reply With Quote
Old 04-20-2016, 03:28 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Another Tire and Wheel Thread But Please Read!!
I Personally think 255's are too wide for a 7" wheel.
I do think 7's and 8's look the best though.
I normally run a 215/70 on a 15x7 wheel with a 275/60 on a 15x8 wheel on static dropped 73-87 trucks. I'm always looking at side wall height and overall tire height,... Along with trying to keep the WIDER front track width in check.
Keith
Convert to disc brakes.
Old 04-20-2016, 04:16 PM   #3
bbbc10
Diggin The SquareLife
why not do 15x8 in the front and 15x10 in the rear? that's what I ran on mine. and 255 is gonna be pretty wide for a 15x7 wheel
bbbc10 is offline   Reply With Quote
Old 04-20-2016, 07:58 PM   #4
cadillac_al
You can usually do what you want but when you put wide tires on narrow rims you wear out the center of your tread prematurely. Lower tire pressures can help but it is best to get the wider rims in the first place.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-21-2016, 02:07 PM   #5
jones9j
jones9j's Avatar
Everyone seems to be worried bout the 255 on the front, that's not as big of an issue ad the 275 on the rear. You have got to get atleast an 8" wheel fir the rear
jones9j is offline   Reply With Quote
Old 04-21-2016, 03:40 PM   #6
Shady Rascal
Shady Rascal's Avatar
No sir. A 275 will fit a 7 inch wheel with no drama. Case in point, GM did it factory on the 454SS trucks. A seven inch wheel with a 275/60-15 tires.
Shady Rascal is offline   Reply With Quote
Old 04-21-2016, 05:46 PM   #7
LDO
LDO's Avatar
anyone have any pictures, i appreciate everyone's input!
Old 04-21-2016, 05:58 PM   #8
bbbc10
I have pics of my 15x8/15x10 if u wana see
Old 04-21-2016, 06:03 PM   #9
LDO
LDO's Avatar
of course
Old 04-21-2016, 07:23 PM   #10
bbbc10
15x8 in the front with a 255/60/15 rubbed in the front and 15x10 rear with a 275/60/15 the drop is 5/6
Old 04-21-2016, 09:08 PM   #11
darkhorse970
darkhorse970's Avatar
^^^nice!^^^
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 04-21-2016, 11:34 PM   #12
Kaysen
I'll gladly send you a pair of nice 15x8s in trade for two of your 15x7s. I'm about to do a similar setup on my 86 but planning on 235/70 or 225/70 on 15x7s up front and 275/60s on 8" wheels out back.
Kaysen is offline   Reply With Quote
Old 04-22-2016, 08:17 AM   #13
LDO
LDO's Avatar
wow, I just saw this. That would be pretty cool. I will pm you.
Old 04-22-2016, 08:18 AM   #14
LDO
LDO's Avatar
Are there any issues with a 2.5 drop spindle (Mcgauhpys)sp.... and running a 15x7 or 15x8 wheel in the front?
Old 04-22-2016, 08:19 AM   #15
LDO
LDO's Avatar
this is a sweet truck BBC!!
Old 04-22-2016, 10:28 AM   #16
slotard
That's an odd combo. You're running 60mm wider tires on 1"/25mm wider wheels.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 04-22-2016, 10:47 AM   #17
SCOTI
SCOTI's Avatar
Actually.... it's not "odd". Height & width were considered here along w/availability. Not all tires come in the exact sizes desired & not all wheels are easily obtained in the sizes needed vs cost. It's a budget compromise that works quite well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-22-2016, 10:57 AM   #18
lolife99
lolife99's Avatar
Actually the 5-lug 15x7's have a 3-5/8" backspace which works out better than the 15x8's which have a 4" bs.
Are you sure they aren't the 15x6.5" van rallys?
they also have a 4" bs.
Keith
Old 04-22-2016, 10:59 AM   #19
lolife99
lolife99's Avatar
This is my old squarebody burb.
7 and 8 inch rallys.
215/70 and 275/60 tires.
Keith
Old 04-22-2016, 12:44 PM   #20
slotard
If you're running 215s on 7s, I'd go for 235s or 245s on 8s. Or, if you're running 275s on 8s, I'd go for 245s or 255s on 7s. Or, if you want 215s and 275s, I'd want to go 2-2.5" wider on the rear wheels.
Not saying there's anything wrong with it, just that there's a significant difference in how the two look and feel.
1973 C20, 350/350
Old 04-22-2016, 01:50 PM   #21
bbbc10
go with western chassis 2.5" drop spindle and you wont have to grind anything if you use 15x8 in the front
Old 04-22-2016, 01:51 PM   #22
bbbc10
thanks!!!!! I got all parts to bag it to lay frame.
Old 04-22-2016, 01:56 PM   #23
LDO
LDO's Avatar
I will try to get a wheel off the truck today or tomorrow and see what is stamped on the back.
I know for sure my spare is a 15x7, that stamping was easy to see.
