04-20-2016, 08:09 PM | #1 |
found longtubes that tuck in frame sbc
Just a post to share the headers i bought for my 68 c10 with a 4/6 drop.
i have a sbc. automatic. 4/6 drop ece kit. I found hat flowtechs 31100flt or 1100flt(non ceramic coated) fit well and clear everything as well as nearly tuck right into the frame. I have about 1/2 inch or less hanging below Enough you could problly shim the engine up a hair and clear the frame almost completely. With a static dropped truck these look to be great choice maybe bagged with modifications. i got the ceramic coated on ebay for 170$. they were the "scratch and dent". they just had a little scratch on the very bottom. They have the black painted for quite cheap. they hit right on the factory bell crank auto shift linkge, so fabrication or a lokar kit is needed. Figured it may help someone on the hunt. i will upload pictures when i get some uploaded.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
04-20-2016, 08:22 PM | #2 |
Re: found longtubes that tuck in frame sbc
I just put a new set on mine last weekend. I do like the way they fit and don't hang down too low. I tried the shortie headers but had too many problems too count.
04-21-2016, 06:40 AM | #3 |
I think I have Flowtech long tubes on my truck, too. I bought the Summit Racing brand, and I heard those or just rebranded Flowtechs. The still hang below the frame, but not as low as the Hedmans I had on there before. They cleared everything in the engine bay when I installed them, but the passenger side header sits very close to the motor mount. Haven't driven the truck yet so I don't know if that will be an issue, but the truck idles and revs in park without the headers touching the mount.
Nick 1972 Chevrolet C10 Stepside |
04-21-2016, 08:45 AM | #4 |
This is very interesting. Please post photos when you can, this might be just what I was looking for.
04-21-2016, 09:50 AM | #5 |
I would also like to see pics if possible. I'm going to be looking for a set for the girlfriend's truck soon. working on the 4/6 drop now.
04-21-2016, 10:00 AM | #6 |
Can you confirm the non ceramic header number please, thanks.
1972 C10 - It might be old, but it's not slow |
04-21-2016, 10:02 AM | #7 |
Found them 11100flt fo non ceramic for those looking.
04-21-2016, 10:12 AM | #8 |
http://www.summitracing.com/parts/ho...del/c10-pickup i have these they fit perfect. my sbc is in the v6 mount location
04-21-2016, 10:37 AM | #9 | |
1970 C10 Short Stepper with 71/72 front clip. |
04-21-2016, 08:37 PM | #10 |
I'm in the process of curing the paint on my new headers. I painted them with Hi Temp Black before I put them on, and I'd like to keep them from turning Rust Red over night.
04-23-2016, 12:06 AM | #11 |
I will post pics in the morning. I tightened driverside down completely, and did find them rubbing the control arm a little bit. I did some massaging and they are cloae now bit fit fine. I could have shimmed my mounts as well but didnt think about it until after the fact.
I would say if you dont mind slight massaging these fit pretty decent.the non ceramic ate cheap,too.
04-23-2016, 12:09 AM | #12 |
Passenger side. close but it does clear.went in easy from the top.
I will get driver side pictures soon. I have these exact headera on my square body and tuck in frame as well with no rubbing anywhere. Very well option for a 73-87
