Old 04-20-2016, 09:56 PM   #1
52napco
single wall top ??
Ok I'm a dummy......How do you tell the difference between the single or double wall tops.
I assume the single is textured on the inside like the outside ??
52napco is offline   Reply With Quote
Old 04-20-2016, 09:58 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: single wall top ??
One, single wall has a light and a power receptacle upper left hand side, behind driver.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 04-20-2016, 10:07 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Top bedside bolts under the bed rail/behind the rear panels? Double wall. Bolts easily accessible from the top of the bed rail? Single wall.
Old 04-21-2016, 08:59 AM   #4
69-72
69-72's Avatar
Also the double wall has a seam down the middle on the inside.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 04-21-2016, 04:35 PM   #5
cleszkie
cleszkie's Avatar
In case you need more indicators:
Double wall has ribbed pattern running front to back on inside ceiling. Single wall has fewer, larger ribs running side to side on inside ceiling.
cleszkie is offline   Reply With Quote
Old 04-22-2016, 01:23 PM   #6
preciador6
What's better single or double?
preciador6 is offline   Reply With Quote
Old 04-22-2016, 02:00 PM   #7
cleszkie
cleszkie's Avatar
Most prefer the single wall because:
1) Doesn't sag like double wall
2) doesn't require the removal of side panels to bolt on or unbolt
3) Has courtesy lights built in
4) Some claim the single is lighter than the double, but I have both and they both weight about the same.
4) They are harder to find because fewer were made in 1972 before the body style was changed to the square body style, which takes a different top. Therefore people want the rarer stuff.
Old 04-22-2016, 02:03 PM   #8
preciador6
cool I just bought a blazer 72 last night has a single wall.
