Old 04-21-2016, 12:04 AM   #1
RaptorSentry
Mushy Brakes at Low Speeds
I am having mushy brakes when driving at low speeds (less than 20 mph). At high speeds brakes the brakes are nice and solid and work great all the way down to a stop. Any ideas what is wrong or anything I can troubleshoot? Just a guess would be low vacuum pressure at low speeds.
Mike
1972 Chevy K20, 350, Long Bed
RaptorSentry is offline   Reply With Quote
Old 04-21-2016, 12:56 AM   #2
70cst
70cst's Avatar
Re: Mushy Brakes at Low Speeds
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-21-2016, 01:00 AM   #3
Rod Run
Rod Run's Avatar
Sounds like a vacuum issue.
Do you have a radical cam, or no canister, or maybe a vacuum leak?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 04-21-2016, 12:29 PM   #4
Texasredneck69-C10
Texasredneck69-C10's Avatar
I would bet you have a vacuum leak or just poor vacuum suction. I you find a leak its an easy fix, if you don't have a leak. you can buy an electric vacuum pump that will fix your issues but they are expensive. Hope that helps.
Texasredneck69-C10 is offline   Reply With Quote
Old 04-21-2016, 01:21 PM   #5
Rod Run
Rod Run's Avatar
Or you buy a vacuum canister because those are cheap. The big Block in my Camaro produces next to nothing for vacuum, so I had to go with a canister and it really helped
Old 04-22-2016, 10:47 AM   #6
RaptorSentry
Thanks for the help, looks like I'll be trouble shooting this weekend looking for the leak.
Mike
Old 04-22-2016, 12:23 PM   #7
davepl
davepl's Avatar
Normally your vacuum canister should hold enough vacuum for one or two brake applications such that you wouldn't notice the lower vacuum available at idle/low speed. But if the reservoir part has failed, you'll notice it. Check to see if it holds vacuum for a minute or two after shutting off the truck.
If its not a vacuum advance issue, have you touched the brakes? Could be air in the lines, because low vacuum usually is described as a harder pedal, or taking more force.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
