Old 04-21-2016, 07:41 AM   #1
ilovesilver97
ilovesilver97's Avatar
1972 door locks and ignition switch.
Can anyone recommend a new set of door locks and ignition switch for my 1972 Cheyenne Super?
I would like Nos or oem. Or is a new set better?
I would like same key.
My ignition switch sticks sometime and the doors don't lock too good right now.
1972 Cheyenne Super Shop Truck Swb fleet 350/350 Turbo Trans,Air,Tilt,Ps,Disc Brakes
ilovesilver97 is offline   Reply With Quote
Old 04-21-2016, 09:04 AM   #2
kcsa75
kcsa75's Avatar
Re: 1972 door locks and ignition switch.
Check with LockDoc. Leon is a locksmith and knows what he's talking about. A while back he was selling lock sets like you're looking for. He can certainly point you in the right direction.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-21-2016, 11:15 AM   #3
ilovesilver97
Thanks I will look him up.
Old 04-21-2016, 04:14 PM   #4
cleszkie
cleszkie's Avatar
My experience:
1)Replace ignition switch with a used OEM Delco unit. The Chinese repops are not as good. You can simply remove the key tumbler from your current switch and install it into the replacement switch to keep the same key.
2) Remove, clean and lubricate your door locks. That will most likely bring them back to life. Also check to make sure your linkage isn't binding. That way, you can keep using your current key for the doors as well. BTW, only lubricate the locks with graphite powder. Liquid lubes will attract dust and dirt and cause the locks to gum up.
cleszkie is offline   Reply With Quote
Old 04-21-2016, 07:34 PM   #5
ilovesilver97
Thank you for the advice. I will give it a try.
Originally Posted by cleszkie View Post
My experience:
Old 04-21-2016, 09:22 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
PM sent
My experience:
You are certainly right about the ignition switches as long as the used one has been tested.
I respectfully disagree about the graphite though. The main problem with graphite is that it attracts moisture, and after a few uses it builds up and becomes a sticky paste. I have disassembled a LOT of door and ignition lock cylinders and the ones that had graphite used in them were in much worse shape than any of them that were lubed with a spray lube. I know part of the problem is that people get really carried away with it though. It's the old adage that if a little is good a lot must be better.... If a spray lube with Teflon is used there is no oil to attract dust and dirt. Any lock will have a buildup of contaminants if they are not flushed once in a while with a good penetrating oil. I never recommend Graphite for any lock cylinder.
LockDoc
Leon
