Old 04-21-2016, 03:29 PM   #1
mdeal
mdeal's Avatar
Interior: Dynamat cover?
Guys, I need some advice. I'm overhauling the interior on my 71 C10 "shop truck". This is by no way a high dollar build, but I have done some nice touches and I believe the right way. My question is, after you use Dynamat(or whatever brand shiny silver insulation) and you have covered up the firewall, floorboard, and up behind the seat; then what do you cover the said Dynamat with that is not covered by the replacement carpet? That was the world's longest run on sentence... I don't really want to see shiny silver aluminum foil behind my seat(tank has been relocated) nor do I want to see it above the carpet line under the dash.
Any ideas?
Carpet? Spray paint?haha.
Examples with pictures would be great! Thanks!
1971 C10 SWB 2WD Driver 350/TH400
2003 Silverado 2WD NBS EC-Daily Driver
"Life is not easy for a boy named Sue."-Johnny Cash
mdeal is offline   Reply With Quote
Old 04-21-2016, 04:26 PM   #2
mike16
Re: Interior: Dynamat cover?
paint the exposed area to a colour more pleasing to the eye?
mike16 is offline   Reply With Quote
Old 04-21-2016, 06:25 PM   #3
KY_GMC
KY_GMC's Avatar
I put replacement firewall padding on the front and will put carpet on the back wall. Eventually I will have a sound system (amps and subs) behind the seat.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 04-21-2016, 06:58 PM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
Finish the deadening job with closed cell foam and mass-loaded vinyl?
Probably not what you wanted to hear....
I'd just get some more carpet or build a nice subwoofer cabinet behind the seats.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-22-2016, 07:16 PM   #5
Z10
Z10's Avatar
I laid down a Dynamat material, followed by Mass Load Vinyl, followed by aluminized closed cell foam. You can see it on my build thread below.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-22-2016, 08:11 PM   #6
notchbackgta
This
notchbackgta is offline   Reply With Quote
Old 04-22-2016, 09:33 PM   #7
Riveted1
Tasty Cakes!
Riveted1's Avatar
You did it right on the vehicle (it looks great btw!), but you got the order mixed up here. It should be vibration damper on the surface, closed cell foam, and the MLV last. The purpose of the closed cell foam is to isolate the MLV from the vehicle. I just don't want the OP to get confused.
Old 04-23-2016, 06:54 PM   #8
Z10
Z10's Avatar
Thanks, ....but I have to disagree with the order. Actually, the MLV is a soundproofing with similar properties as lead. The aluminized closed cell foam serves two purposes, sound absorption and reflecting ambient heat/cold. My thought process was to isolate the harmonic vibration wth damper material like Dynamite, followed by sound proofing with MLV, then isolating additional sound and heat/cold with the aluminized closed cell foam. I also followed all of that with carpet padding then carpet.
http://www.soundproofing.org/infopages/flooring.htm here's a link to MLV which is used in the walls of home theaters etc. The stuff is great but it's very heavy and is hard to shape. I've also had issues finding a suitable adhesive to apply it to vertical surfaces such as the back of the cab and the inside of the doors. The best so far that I've used was Locktite 300.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-23-2016, 09:57 PM   #9
notchbackgta
The CC foam is to isolate the MLV from rubbing on the Dynamat and not introduce a new source of sound. Also, it would behoove you to put the reflective barrier before the MLV so the "heat" is reflected before it gets to the MLV and it isn't absorbed and then will heat soak and slowly transfer that heat through the CC foam anyway.
Old 04-24-2016, 12:42 AM   #10
Riveted1
Tasty Cakes!
Riveted1's Avatar
Yeah, notchbackgta has it right. CCF's purpose is to isolate. So the MLV should be isolated from the surface of the vehicle.
Z10, I guess I misread your build page, b/c I thought you posted that you applied the deadener, CCF and MLV. Anyway, with your CCF having an aluminized layer, it should probably be decoupled from the vehicle, too. But, we may be nitpicking. I'm not sure how much you'd notice with a layer of carpet padding and carpet on top of all of that. It definitely is quieter than it was from the factory!
BTW, if you go to https://www.sounddeadenershowdown.com/, Don, the owner, did lots of testing (a lot of his results were posted on an audio site I frequent.) He sells his own product now, but his site is still a good resource even if you don't buy from him. My .02
And sorry, mdeal, your original post has taken a bit of a detour.
Old 04-24-2016, 08:09 AM   #11
snipescastle2
snipescastle2's Avatar
Talking Re: Interior: Dynamat cover?
I have the same situation. I bought several yards of that speaker cabinet felt/carpet to cover the rest of mine, probably going to use 3M super 72 blue spray adhesive to attach it to the surface of my sound deadening material...
you can find the speaker carpet/felt, etc.. Walmart.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
