04-22-2016, 09:27 AM | #1 |
Painting inside cab different color
Im really wanting to paint the inside of my cab (Gray) a different color than what im going to paint the outside (Black). Im just not sure where to stop the color break. Im assuming everything inside the truck would be painted the same color until I get to the interior rocker panels, and then the interior rockers would be painted the same as the exterior? The whole inside of the door would be painted gray and then the outside of the doors would be black?
I guess I haven't really paid to much attention in the past to other trucks that have been painted a different interior/exterior color so any opinions are welcome.....
67 C10 SWB Chevy |
04-22-2016, 09:43 AM | #2 |
Re: Painting inside cab different color
All red inside would look good with the black outside...
71 C10 I6 250 TH350 power steering and power breaks... |
04-22-2016, 10:46 AM | #3 |
Use the weatherstripping around the door jam as the break, so the door jam would be body color, on the other side would be all the interior color. I would paint the entire backside of the door the interior color with just the outside body color.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-22-2016, 11:56 AM | #4 |
My truck is a different shade of green inside the cab then on the outside.
I am thinking of doing my exterior roof/hood/lower(below moulding) in a very metalic gun metal, I might paint the interior the same color at that time.
1972 C10 - It might be old, but it's not slow |
04-22-2016, 12:02 PM | #5 |
Pinch weld[where the rubber seal goes is a grat place to stop the "other" color. Jim
04-22-2016, 12:06 PM | #6 |
I would be careful going out of the box on the inside color. I know its your vehicle, but doing something you have to defend later is a bummer. I have an expectation of what the inside color should be when I look at a car/truck. For me it's kind of a standard, like the gas pedal on the right and clutch on the left. If you deviate you get to go on defense! Try to find a sample an make sure you really like it. First thought in my head is, didn't have enough time or money to keep going on to the inside.
My two cents, probably worth the price paid!
White K20 |
04-22-2016, 01:27 PM | #7 |
67 and some 68 trucks painted the inside the trim color. So a black truck with an all reds interior was correct. Its really a matter of finishing it out properly. If you want a series of greys inside it could look nice. Just be aware a non-original interior color/scheme can be a negative selling point.
Here is an example of a yellow truck with the fawn trim and sheetmetal as the factory did it. The cab trim color ended at the weatherstrips as noted before and the doors at the edge of the skin like a cheap color change.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-22-2016 at 02:02 PM. |
04-22-2016, 02:08 PM | #8 |
In reflection a GLOSS Black truck and a silverish gray trim/interior would look very good. A lot like one of my favorite vette combos, black/gunmetal.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-22-2016, 02:56 PM | #9 |
motor exploder
I didn't paint my interior a 'different' color, but I did use a matte clear on the interior to contrast the gloss on the exterior. I broke the color scheme on the doors like the pic that SS Tim posted above and then used the break for the weather stripping for the rockers.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
04-22-2016, 03:02 PM | #10 | |
The doors are trickier....also depends if you have the metal interior panels (vs. plastic) and if you want them to be a different colour (eg: door body colour, metal panel interior colour kind of thing...or vice versa) |
04-22-2016, 03:11 PM | #11 | |
Interesting, did you go a full "0" gloss or a matte like 20%? Does it show up in pictures?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-22-2016 at 03:17 PM. |
04-22-2016, 10:22 PM | #12 |
My exterior is going to be white with black stripes. I plan on going black on all the interior. I'm having the doors and door jams painted white. I will run black panels on the door. I'm hoping the white top section of the door leaves just enough white to tie into the outside but the black panels tone it down enough to flow with a black dash seats carpet and roof. We will see how it turns out.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
04-23-2016, 07:17 AM | #13 | |
motor exploder
My interior isn't finished, but the seats, door panels and dash pad will be black (shifter, pedals, steering wheel, door pulls and window cranks are all anodized black) and the carpet will be charcoal.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 04-23-2016 at 07:23 AM. |
04-23-2016, 07:41 AM | #14 |
Very Nice effect! Thanks for the pictures.
04-23-2016, 07:44 AM | #15 | |
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
