Old 04-22-2016, 09:39 AM   #1
V30 mongo
Starter mystery find
First off: 1988 V30 CC 6.2 diesel sm465. On trying to start the truck ,the starter "stuck". Trying to push start failed, the engine was locked up. After removing the starter the truck push started. Later on, while replacing the starter a washer was found in the bell housing with gear marks. The washer must have been caught between the starter and the flywheel. The washer looks like a 1/4" or 5/16". Question? Is there anything in the bell housing/ clutch that uses this type of washer or did it just "find" it's way in there. The truck starts fine now. Will it be ok or should I have to remove the transmission / transfer just to check for a missing bolt and washer?
1988 V30/6.2/Sm465/NP205/5x6 4.56 axle/12,000 lb.GVW/Ramsey L600 front winch,Chelsea 321PTO on trans/ Ramsey L800 rear winch,Chelsea 352PTO on transfer/ custom steel flat bed with rear rollers.
V30 mongo is offline   Reply With Quote
Old 04-22-2016, 11:56 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Starter mystery find
Not that I know of. Maybe it got stuck to the starter some how when being replaced.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
