Old 04-22-2016, 11:59 AM   #1
davepl
davepl's Avatar
Pertronix tach signal
I have a Pertronix III module in a stock distributor body. I have the tach hooked up to the negative side of the coil. The first tach I tried didn't work with it at all, but a second one of unknown origin (but still a repro - hope it wasn't NOS!) did work.
I still think it reads high, and my theory is that the Ignitor III does multi-spark at low RPM, which fools the tach that can only see the coil.
Normally I'd think if you had an external ignition box that did multispark you would have a tach wire output that was only triggered once per cyl, but there is no such tach wire on the little module, so...
Is there a solution? If its multispark throwing it off, no amount of tach filtering is going to fix that.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-22-2016, 12:50 PM   #2
Coley
Coley's Avatar
Smile Re: Pertronix tach signal
Interesting....so you only have one working tach to test with at this point?
do you have an extra generic tach you can check against?
I'm running a Pertronix unit in my stock distributor and so far so good but it is the 1181 Pertronix unit. (not sure what the difference is between that and the Pertronix III).
It starts great, super reliable...no problems or issues and seems to run the tach without an issue.
That said, I don't think these tachs are notoriously accurate but it seems to be pretty close.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-22-2016, 12:54 PM   #3
BrianG
BrianG's Avatar
I'm pretty sure that I have read about this with the Petronix III. I seem to recall that other users have 'downgraded' to the Petronix II to resolve similar issues. I couldn't find the threads though. Maybe a tach filter would help, but who knows.
Edit: I see you were having a similar issue quite a while ago. Did you ever figure this one out Dave?
http://67-72chevytrucks.com/vboard/s...d.php?t=634958
I have a similar issue, but its with a new AC-Delco distributor. The tach reads 4,000 with the ignition on, but not running. Then reads up from there when the engine is running.
BrianG is offline   Reply With Quote
Old 04-22-2016, 01:00 PM   #4
davepl
davepl's Avatar
Unless the multiple sparks come so close together that a filter would eliminate them as noise, I'm not sure if it'd help.
That other one thread you mention was the first tach, which didn't work right with it at all (read 2000+ when key on, engine not running). All I could do was replace that tach.
Old 04-22-2016, 01:14 PM   #5
BrianG
BrianG's Avatar
Bummer, that's what I thought you were going to say... looks like I'll be ordering a new Tach. The one I have is new and unused, but I bought it a year ago at least, so getting my money back would be a long shot at best.
So, is this the same vehicle, same distributor, and just coming around again? Has it been a continual problem, or a new one?
Old 04-22-2016, 01:24 PM   #6
davepl
davepl's Avatar
I've had this tach in it for a year or so, so I think I just did't follow up on the other thread. The "reading too high" would be a continual problem, it just was a minor nit compared to things like the trans not working, so haven't worried about it much until now.
