Old 04-22-2016, 03:30 PM   #1
General23cmp
1970 chevelle exhaust manifolds
Any idea if these will fit? Using factory, 1972 BB truck mounts on a 454 engine. Engine has 68-70 Chevelle/Camaro BB manifolds. I assume trucks had specific manifolds.
General23cmp is offline   Reply With Quote
Old 04-23-2016, 02:05 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: 1970 chevelle exhaust manifolds
show a pic of both manifolds
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 04-23-2016, 05:03 PM   #3
General23cmp
these are all I have right now.
Old 04-23-2016, 05:04 PM   #4
General23cmp
This one
Old 04-23-2016, 05:06 PM   #5
General23cmp
And this one
Old 04-23-2016, 07:22 PM   #6
dennislbrooks
Here is what mine look like in my 67. I had a sbc hooked to a 350 turbo and a NP208 transfer case. I left all of these in the same positions and moved my bbc mounts forward to allow the bbc. This gave me valve cover clearance but I did have to raise the bbc on the bbc mounts 1/2 inch. I used the expensive bbc mounts on the motor - pre 72. My manifolds are not 1968 c/k10 396 - but later years similar to your chevelle's.
Mine dump same as yours.
I trimmed my sbc fan shroud to fit the fan on the bbc. My alternator runs directly off the 1 of the 2 groove pulley on the power steering pump. Yours may not.
Let me know if you want any other pics.
Old 04-23-2016, 08:37 PM   #7
Mike C
Mike C's Avatar
I'm pretty sure those Chevelle manifolds are the same as the truck ones. At least the '73 and up ones. I don't remember precisely what my '70 402 GMC manifold looked like.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
