Best drop-in distributor?
OK so it looks like there is no saving my stock points distributor. I have used the Pertronix I and later on the Pertronix III, and while they did the job for a while, it's gotten to the point where this dizzy is just too far gone. I'd like to send this out to get rebuilt and converted to HEI, but in the meantime I need something. I don't trust any of the dizzys on eBay, and I don't think at this point that I want to go back to points (ballast resistor is long gone). I also don't want to spend a ton or go with a racing distributor. Any suggestions?
Re: Best drop-in distributor?
I wouldn't bother with the HEI, I went with MSD like 10 years ago and I've never had to mess with it. Ran better than ever the second I fired it up.
I bought a Pertronix stock-bodied distributor with an Ignitor III module in it, and tach issues aside, it's a powerful and reliable setup. It also looks bone stock.
![]() Join Date: Feb 2013
I decided to go with a Davis Unified Ignition (DUI) and I am very happy so far.
after doing quite a bit of research on different options the DUI seems to be worth the price. |
![]() Join Date: Jul 2000
The MSD Street-Fire is an inexpensive option. Quality-wise it's probably closer to the more expensive MSD products than the no-name eBay specials. And it's backed by MSD.
Also, GM #93440806 is a quality distributor, but has 20 degrees vacuum advance out of the box, which you will probably want to limit 10 degrees. This can be accomplished with an inexpensive Crane kit.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Check into the MSD ready to run. If the price is a major stumbling block look at a Skip white then put in a Delco module and forgetaboutit.from what I'm reading, the major problems with the skip White HEI is that some have had the modules go out. that is why I recommend the Delco HEI module
What are you going to do with your Pertronix set-up?
Moderator
![]() Join Date: May 2007
I've used several eBay specials (Skip White, etc), no problems.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Dec 2006
^^^^ This. I bought a Skip White on E-Bay for around $50 10 years ago, and no problems ever. I had points before and the main difference is that the engine jumps to life when I start it.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
I replaced the HEI in my sons truck with a new HEI from Summit, was around $90.00 shipped to my door ready to drop in ,includes cap and coil,has been excellent for a couple of years now
I had a skip white and GM performance and you could barely tell the difference. The GM performance might have spun a bit smoother by hand. $45 compared to $125 (estimates) was a big difference in price for only a small difference in quality. I've always heard great things about the skip white setups, get new plug wires and run a new 12V hot wire from your fuse box.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
x2 on the summit, Ive had several. I did have one of them where the pickup went bad but other than that no problems
#13 |
Go with a stock HEI-It's a no-brainer. Cheap and reliable.
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
#14 |
x2 . I like the MSD stuff but I put hei's in everything.
I bought an HEI for a pontiac back in 97 for 49 bucks rebuild from NAPA. still kickin I paid 350 bucks for a drop in MSD . it didn.t give me any problems either |
#15 |
Every time it comes up, I hear to avoid Chinese knock-off HEI, but that GM HEI is rock-solid up to a decent street RPM.
Are the Skip White and Summit ones made in the US? Anyone know? They seem to have a good rep too.
#16 |
motor exploder
I have used a D.U.I. distributor - it was a nice unit and kept my big block lit past 6500rpm.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#17 |
pretty sure the skip white are chinese, but look at the reviews...
#18 |
I have installed 3 Skip White Dizzys in 2 different trucks, and all had the module fail within 500 miles.
I did a bunch of research trying to find one of the "made in USA" distributor people recommend and there are none unless you want to pull a 30 year Distributor out of a junk yard... unless I missed something. The DUI I installed has at the very least ben touched by someone that can write in English as it is marked on the bottom with an engraving pen 24* at 3000 rpm... and the timing light confirms this to be true. |
#19 |
![]() Join Date: May 2012
The skip white ready to run is most definitely Chinese. I spent more than twice as much on MSD wires than the distributor. Why, because I want thru put. Making a distributor is right up there with a TV set or PC. They are basically all the same and all work. But all things equal. A drop in for a run of the mill pack is fine. But if your building some sort of hypo, then I'm guessing you wouldn't be posting drop in distributor questions.
I bought the skip white because it was cheap and works fine... for the past two years. Spend your bucks on wires! Want to escape Chinese made car parts? Then move to a different planet... that horse left the barn long ago? ![]()
White K20 |
#20 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#21 | |
Posted via Mobile Device |
#22 | |
http://www.msdignition.com/Products/...stributor.aspx
#23 |
I thought MSD was all imported now, as mentioned many friends have had issues with products in the last 7 years or so.
#24 |
Post Whore
![]() Join Date: Feb 2016
I am wondering what has gone wrong with your current set up that is forcing you to make a change. No mass produced distributor is going to drop in and work correctly especially if you have made other changes to the vehicle. The stock unit was a compromise made by GM to balance driveability, warranty issues and COST. Truly the only way you will have a distributor that makes engine run at its best is to have it curved by someone who understands how it is supposed to work and is willing to spend the time to get it right. Most all of your choices are involving a compromise of some sort. Remember that there are many good aftermarket units out there that have quality engineering and good parts but are assembled by minimum wage workers in foreign countries who will never see you. I won't go into all of them but I highly recommend that you tear your's down to double check the assembly process prior to installation. If your planning on long trips or offloading look at the cost of carrying spares if the unit will allow field repairs. HEI's are work well, but are difficult to curve properly as they were designed for low compression smog compliance, plus when they fail it is usually without notice and it is difficult to do field repairs. Pertronix units work well if installed correctly (once again good idea but victim on cheap manufacturing) and if you distributor is worn out or has a bent shaft it won't fix that. The plus is you can for most vehicles switch back to points in the field and get home if it fails. For GM vehicles I use an old 50's or early 60's cast iron unit with a Pertronix unit. The old distributors have much larger bearings, the machining is better and the cast housing is less likely to warp. The ease that the pre-HEI units can be recurved if I change something on the truck (cam, convertor,gears,etc) makes things easier in the long run. This with the peace of mind that a spare set points in the glove box is what makes the choice for me.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#25 |
