Old 04-22-2016, 06:15 PM   #1
notchbackgta
Headliner
I started working on my headliner yesterday. I only had the front panel when I got my burb and it was already cracked, taking it out another piece fell out, but I was able to use it as a template, thank goodness because they are all a pain to fit anyway.
It's not done fitting, but I am too hot to continue to work on it today. I have to trim all three panels width a bit so they touch the strips a little better, I also think I need to put in another two screws into each trim strip on the bows so the strip hugs the bow better. I wish I had gone 4 across instead of three, but now it will be 5.
I may pull it down later so I am ready to go at it again tomorrow morning for the final trimming and on to covering. I am also going to put up a couple layers of Thinsulate above it for sound absorption and thermal insulation. I wan to keep as much heat from transferring into the cabin from the roof.
For the panels I got 1/16" HDPE sheet from McMaster Carr, the aluminum strips are 1" wide 1/16". I live near McMaster, so I did will call for the sheet. I had to buy 4'x8' sheet since the panel width was about 57" across.
The squares you can see through the plastic are 18"x18" pieces of FatMat 80mil.
I am also working on making some of the rear interior panels with some 3/32 HDPE
notchbackgta is offline   Reply With Quote
Old 04-22-2016, 09:07 PM   #2
vectorit
What?
vectorit's Avatar
Re: Headliner
Good job!
I love seeing people put effort into the burb headliner, since all too often it seems to be the last thing touched on the burb.
I hear you about it being to hot... I did my headliner work in the summer, and I was by myself so. Yea, it took a few days to get a nice end result.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-22-2016, 10:59 PM   #3
notchbackgta
Re: Headliner
Originally Posted by vectorit View Post
Good job!
Too hot for me is really anything over 55, I think it was in the 70s today
Old 04-23-2016, 01:41 AM   #4
Average Joe
Average Joe's Avatar
Re: Headliner
Nice work!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 04-23-2016, 08:51 AM   #5
Bigdav160
Bigdav160's Avatar
Re: Headliner
Yes, the Suburban headliner is a tricky job. Each piece has a decreasing crown and a slight taper to it.
I'm glad mine was in good shape. I even found some nice plastic strips on the parts board.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-23-2016, 09:34 AM   #6
notchbackgta
Re: Headliner
Yeah, I thought all the bows were the same until I took them down and had them next to each other. The taper is a huge pain too. The rear most panel was the easiest to make fortunately and I used the measurements of the ends of the first and last to see that the panel was a trapezoid.
My plastic strips were all brittle, as I tried to get them off they splintered.
I decided to take the middle panel down last night and trim it again. I made it a touch too short now, but I don't think it will be noticeable once I get it covered.
I am also using a heat gun to get the curve at the sides into the panels where it goes into the slope of the roof. I heated a spot in the front one too much and it put in a pleat but it is above the sun visor, so it shouldn't be too noticeable.
Old 04-23-2016, 10:02 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: Headliner
Looks good. I have to do the one in my Panel Truck. I have a complete Suburban headliner and strips and I am hoping they are the same....
LockDoc
Leon
