04-22-2016, 09:49 PM | #1 |
Ah troubles on the way home!
So here's something new been picking up the gf from work every day in the truck and has been fine, cruised around back and forth an hour a day. Well today was different a bit colder but was running fine when I got there and sat idle. So we are headed home and just down the street the truck starts bogging my first reactions was oh heck I'm empty..
Started right back up made it to the gas station. Put 40$ premium in. Looked in my gas tank I could see there was gas still in there so thought hmm maybe it isn't picking up fuel. Then I saw the fuel filter was full. As soon as I let the throttle out I lose any power to the engine now it won't hold idle for long sits at maybe 3-400 rpm then dies after 10 seconds and smells like it's running extremely lean. 1968 c10 with a 283 and Saginaw 3 speed
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713 Member of tailgate association of manitoba |
04-22-2016, 10:52 PM | #2 | |
The Older Generation
Re: Ah troubles on the way home!
If you are running a stock carb there may be a small cartridge filter in the fuel inlet on the carb. If so try changing that. Also the fuel sock on the pickup tube in the tank may be plugged. LockDoc
04-22-2016, 11:17 PM | #3 |
I'll check the small filter and there's fuel going into the glass filter after the fuel pump still. I'm using it as a gas line sight right now to monitor this week long test. I can hear fuel squirt what I pull on the throttle linkage This is a brand new gas tank relocated to the rear which I should have mentioned.
04-22-2016, 11:58 PM | #4 |
Is the tank vented? Did you notice air sucking in when you took the gas cap off?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-23-2016, 12:03 AM | #5 |
Hmmm, sounds like a lot of things. Ignition module possibly going out is the first thing I am thinking.
Run through the fuel system and eliminate that first which should be easier, then ignition. Do you have spark? |
04-23-2016, 12:20 AM | #6 |
Tank is vented, didn't hear any presume or suction. My first thought was to check vacuum leaks
04-23-2016, 01:02 AM | #7 |
disconnect the fuel line at the carb, run a rubber hose into a jar and have someone crank the engine over, you should get a steady stream of gas, this will eliminate if it is the fuel pump going bad or not,also you mentioned that you have a glass fuel filter, please get rid of that immediately and replace with a see through plastic one, the glass can crack lengthways and spray gas all over the engine, it has happened to me and others on this forum, luckily I didn't burn my truck up...and like others have said, replace the small filter in the carb.....let us know what you find out.....
04-23-2016, 01:43 AM | #8 |
?? I know what extremely RICH smells like but not extremely LEAN?
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
04-23-2016, 07:22 AM | #9 | |
04-23-2016, 10:54 AM | #10 |
I will change all the filters and give everything a good clean to start, maybe see how black my spark plugs are and yes I meant rich. It's just odd that it would be fine literally until we left sat and idled for 20 mins normally
04-23-2016, 11:24 AM | #11 |
don't know what kinda carburetor you have but flooding/ blubbering/ rich/ won't idle/ loading over is usually trash in the needle & seat on the fuel inlet. I have Holleys on 3 old vehicles. Easy to clean or replace needle & seat on them, don't remember on Edelbrock/Carter/Rochester. Trash the size of a pepper flake's all it takes. GOOD LUCK!
04-23-2016, 12:08 PM | #12 |
Use a metal fuel filter not plastic those also can lead to issues and leaks. Sounds like your needle and seat has something holding it open and letting in too much fuel. Also check and smell your oil for fuel in it. If there's any question whether fuel is in oil change it before doing any running of engine
04-23-2016, 12:25 PM | #13 |
The carb is a quadrajet and I'll check those right away
04-23-2016, 12:31 PM | #14 |
Has anyone had such a moment as this? A moment of panic and complete ignorance where the answer was just to look at what's going on? My freaking brake booster vacuum line popped off...thank you I'm an idiot.
04-23-2016, 01:05 PM | #15 |
The brakes should have felt harder to press when it happened, but prob went unnoticed due to the engine stumbling all over. Yeah sometimes things aren't so obvious lol
04-23-2016, 09:49 PM | #16 | |
Ahh, a day in the life of a do-it-yourselfer...... Been there done that. LockDoc
