Old 09-27-2003, 10:07 PM   #1
Mountain Man
Is a L82 a good engine
I have been looking at some late 70's Vettes and early 80's.
Is the L82 a desirable engine, and what type of HP would it have.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 09-27-2003, 10:34 PM   #2
Randy70C-10
Randy70C-10's Avatar
L-82 is a good engine, but at the low end of horsepower producers. They make 180 horses on a good day.
Randy70C-10 is offline   Reply With Quote
Old 09-27-2003, 11:21 PM   #3
gashog
Active Member
gashog's Avatar
L-82's were the optional engine and L-48 was standard. The L-82 did feel quicker to me. Better heads, cam and if I rememer correctly slightly higher compression.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z
gashog is offline   Reply With Quote
Old 09-28-2003, 10:32 PM   #4
Mike C
Mike C's Avatar
The L82 was rated at 245 hp in the 73 and 74 Z/28s. It was 255 in the 74-75 'vettes and down 30 more after cat converters show up. It is ~ 9:1 compression and has 76cc heads that have 2.02/1.60 valves and screw in studs and guideplates. It was the most powerful SBC from its intro until the LT1 debuted. They run OK, but the open chamber heads are down 20hp compated to the earlier closed chamber ones, all else being equal.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-28-2003, 10:36 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
So that is 255 net HP?
That is pretty good....i didn't know they produced that much. A Vortec 350 produced 255 net HP.....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-29-2003, 12:54 AM   #6
sameyrasmea72
sameyrasmea72's Avatar
For the years that you are looking at, unless it's pre 74 where you could get a BB, the L-82 is the best your going do. These cars aren't real desireable YET, but I guess they will be next inline. A '75 convertible L-82 (last conv.)will be highly desireable someday and sortof already are, if you see any of those while your looking.
I personally (jmo) would stay away from 76,77,78. According to my dad, who owned a used dealership at that time, said they were the worst vett ever made with the exception of the '84. Again just my opinion . If you find one you like get it!!! They are old enough that any of them should only go up in value.
A 1982 L-82 ( i think they offered L-82 til'82) seems like it would be desireable soon. Last of the L-82s? and last of the body style.
A 1983 is ultra rare if you see one of those.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
