Old 04-23-2016, 03:30 PM   #1
East_Bound
East_Bound's Avatar
Coolant leaked out of exhaust flange
What's up guys -
So today, I fixed my exhaust leak from the exhaust flange, which is great. But while I had the exhaust flange off and open, I discovered something else:
I had the first exhaust pipe separated nearest to the front of truck, and after having it off for a couple minutes, I bumped it pretty good and had some bright green coolant drip out of it. After a few pumps putting back the thread and nut for the flange, more coolant would spill out. I'd say around 8 oz of coolant. Coolant did not leak out of rear exhaust flange (nearest to firewall)
I am aware this is a sign of a blown head gasket or something internally wrong with the engine, but is there anything else that can cause this? Why would coolant be coming out of one exhaust pipe and not the other? The exhaust flange is straight up and down while the one nearest the front of truck is at a 45' degree angle, so it shouldn't have to do with gravity.
There is a small coolant hose line right above the exhaust flange that drips on top of the flange, but could the coolant seep into the exhaust overnight before being able to be burn off by a hot exhaust? Any info helps!
East_Bound is offline   Reply With Quote
Old 04-23-2016, 03:58 PM   #2
frankslagoon
Re: Coolant leaked out of exhaust flange
seems like a lot of coolant. if it were leaken from inside the engine you should see white smoke
frankslagoon is offline   Reply With Quote
Old 04-23-2016, 04:56 PM   #3
East_Bound
East_Bound's Avatar
No white smoke has been seen. Runs very good and hasn't had any sign major sign on decrease in performance. But there must be a reason.
Old 04-24-2016, 04:20 PM   #4
storm9c1
*** That's interesting ***
storm9c1's Avatar
Fluids can do weird things, and follow strange paths. If you know that you are weeping coolant from places, I'd fix those issues first. Also check your freeze plugs. I've had those leak and cause coolant to drip from places that make no sense (like coolant dripping from inside the starter, lol). What engine is this? Some engines (but not SBC) have exhaust manifold bolts that go into the coolant jacket. I had a Mopar big block that was leaking coolant out the exhaust that was caused by this. The previous owner replaced the stud but did not put sealant on the threads.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 04-24-2016, 08:21 PM   #5
East_Bound
East_Bound's Avatar
250 block out of a 1970 Nova, original 230 heads.
Old 04-26-2016, 11:01 PM   #6
sixnineK5
My 69 k5 has a 250. Strangest thing is that I have noticed coolant on top of the intake/exhaust near the no.1 cylinder. Have no idea how it gets there, it runs smooth with no smoke or oil contamination-
sixnineK5 is offline   Reply With Quote
