Old 04-23-2016, 03:47 PM   #1
70olbo
What fluid is this? (Inside wheel)
I noticed this the other day:
I have since taken the wheel off and looked inside the drum at the wheel cylinder but saw no obvious fluid on the outside.
I looked while the wheel was off inside the wheel area and it looked like it could be coming from the area where the arrow is in the other picture. Does anyone have any ideas?
Is it safe to drive or should I wait until I have it looked at?
1970 k10 4x4
70olbo is offline   Reply With Quote
Old 04-23-2016, 04:04 PM   #2
frankslagoon
Re: What fluid is this? (Inside wheel)
does it smell like gear lube
frankslagoon is offline   Reply With Quote
Old 04-23-2016, 04:16 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^^ X2 -- check the front diff oil level.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 04-23-2016, 04:36 PM   #4
GRX
GRX's Avatar
Classic ... bad axle shaft seal.
GRX is offline   Reply With Quote
Old 04-23-2016, 05:21 PM   #5
Chknlyps2
1970 k10 4x4
If it is just seeping out it will be fine if you keep the diff full, but if oil can come out then dirt, grime and muddy water can get in. The air blowing by from driving will get gear oil all over the bottom of the truck also.
Here is a link that shows seal replacement after you get the axles out. http://d44tech.com/axle_seals.html
Chknlyps2 is offline   Reply With Quote
Old 04-23-2016, 05:24 PM   #6
70olbo
Thank you!!!!
Thanks all for the info. I will check the levels for now.
Old 04-23-2016, 09:16 PM   #7
frankslagoon
park it with the drivers side high and it won't leak out while the trks sleepen
Old 04-23-2016, 09:52 PM   #8
67chevy_hotrod
67chevy_hotrod's Avatar
Axle shaft seal x2
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 04-23-2016, 10:02 PM   #9
chefk85
chefk85's Avatar
its dry above it otherwise I might think something else could've gotten on it such as brake fluid or engine oil. I would be checking axle seals x3.
http://67-72chevytrucks.com/vboard/s...25#post7532025
71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress.
79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos.
93 Burb K1500. 350/4l60e Parting out.
2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles!
chefk85 is offline   Reply With Quote
