Old 04-23-2016, 06:49 PM   #1
robber grin
62 C10 neutral Safety Switch
62 C10 stock wiring
75ish GM van column
what wire do I cut from the ignition switch to go to neutral safety switch?
64-66 is purple I believe but mines a 62 and there's no purple wire only pinkish
robber grin is offline   Reply With Quote
Old 04-23-2016, 07:41 PM   #2
lumpy63
lumpy63's Avatar
Re: 62 C10 neutral Safety Switch
Try using a test light on the ignition switch to see which wire is energized in start position this will be your start wire . Make sure truck is in park! route this wire through safety switch and on to solenoid. D id you have any issues with neutral switch interfering with upper column mount? I had to relocate my switch further down so I could clock my column correctly
lumpy63 is offline   Reply With Quote
Old 04-24-2016, 07:49 AM   #3
robber grin
I got lost in the momentary blur of spaghetti wiring. I got it - and it was purple!
I relieved the side of my bracket to make room for it where it was on the tube but it's a bear to get at.
thanks
