'69 K10 PS lines
Last week, I was driving home from work when one of my PS lines blew. I finally had time to investigate today, and found a hole in the steel part of what I assume is the low-pressure, return hose--I assume so because the rubber is clamped onto the steel on both ends rather than having the formed connections on the other hose. Rubber is in good shape, so I just need to replace the steel end.
What's a good source for something like this? All my searches at regular parts houses turn up generic rubber line, but it's the steel part I need.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Re: '69 K10 PS lines
Since you just need to form a section of line and you have the fittings it shouldn't be an issue making or having a replacement made. Since its the steel line it sounds like a rub through of some sort. Make sure you correct that too.
If you must have a bolt on part look in the classifed section for used PS lines or post a WTB, want to buy, (after becoming a subscriber) ad of your own. Or simply pull the section in question and hit the yards for a workable match to your in hand sample.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I think we bought this from jegs for the high pressure. Fit well and seemed to be bent similar to oem. We had a different fitting put on it to work with a different power steering pump, but it bolted up to the oem gear box no problems.
http://www.jegs.com/i/Gates/465/355240/10002/-1 For the low pressure end something like this would work if it had a 90 degree bend in it. Our autozone ordered one for us. They looked up a few different model and year trucks before finding the part number http://www.jegs.com/i/Gates/465/353250/10002/-1 |
![]() Join Date: May 2010
Junkyard. I saw 3 of them last week at a yard near me. These were 2WD trucks, but they are may be the same as the 4WD.
Unfortunately, none of the yards within 100 miles of me will do anything but pull these trucks straight to the crusher. But salvage is still a good idea; I'll have to some looking around further away. Having the piece made is a good idea, too. I can't do it myself because my flare tools won't do steel, but maybe a local parts house can.
Still, I appreciate all the ideas.
Inline tube has them or I can get it for you, They run you around $20
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
Thanks for that, pickupman; I didn't see your post till after the fact.
I found the part at LMC and ordered it. It was here in just a couple days, and I put it on today. The bend was not exactly the same as the stock, but it was close, and putting it one was not real trouble. I did bugger up the clamp, so I had to replace it with one on hand. I got the system bled easily following the manual; test drive tomorrow. Additional note: GMC Paul also carries the part. Now I know.
