04-24-2016, 02:30 AM | #1 |
At the body shop.
Finally got my 406 back!
See how fast I can put this together again. Almost a year at the machine shop.
" That didnt make it any newer " " Dont antique the equipment " |
04-24-2016, 06:58 AM | #2 |
Re: Finally got my 406 back!
Love the color, what color code is it?
04-24-2016, 07:59 AM | #3 |
Do you mind sharing the specs on the 406? I've had a never rebuilt 400 sitting on a stand for years that I swear I will build some day so always interested in what other people are doing with them.
04-24-2016, 10:37 AM | #4 |
At the body shop.
04-24-2016, 10:41 AM | #5 | |
At the body shop.
9.9:1 200 cc dart iron eagle head Comp hyd roller 288° 1.52 roller rocker Rpm air gap intake 850 dp holley 5.7 rod.. Has ran a 12.0xx e.t @4160 lbs Is a riot to drive.
04-24-2016, 11:33 AM | #6 |
You have any idea what that motor will Dyno at?
1976 C-10 Stepside 2005 Chevy Avalanche Z71 2008 Subaru Wrx - Modified Track Car 2012 Harley Davidson Fatbob Custom My build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703077 |
04-24-2016, 03:43 PM | #7 |
04-24-2016, 05:01 PM | #8 |
At the body shop.
04-24-2016, 05:03 PM | #9 |
At the body shop.
It ran 11.99 at 4160lbs before, so around 480-500 depending on which calculator you use. But never been on a dyno.
04-24-2016, 05:05 PM | #10 |
At the body shop.
Before and now.
04-24-2016, 05:41 PM | #11 |
Love it! Hate to bombard you with questions but, what is that rear tire size, wheel width, and backspacing?
That's the look I am after. |
04-24-2016, 05:49 PM | #12 |
awesome transformation man!
04-24-2016, 08:33 PM | #13 |
At the body shop.
No worries, 15x10 3.5 bs but... should have been. 4.5 bs had to do surgery to fit the 325-50 drag radial
04-25-2016, 11:48 PM | #14 |
At the body shop.
Well it fought me all day Sunday. But this made it worth it.
05-01-2016, 12:00 PM | #15 |
At the body shop.
Well it's in, and time for the it's and bit's.
New transmission crossmember went in decent. Finally got the new converter and new th400 together. It's the last transmission my friend Rudy built for me before he passed, feels weird. Had it since '08 as my spare.
05-02-2016, 02:40 AM | #16 |
At the body shop.
Under its own power, first time in a while.
05-03-2016, 10:05 AM | #17 |
Truck looks great, your crew chief looks young but won't take too long before being behind the wheel.
The converter looks stout , what's the rated stall, and what's the rear gear ?
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
05-03-2016, 10:56 AM | #18 | |
At the body shop.
Spec rite out of California http://www.specriteconverters.com Billet front half 3200 ish nitrous converter And has a 3.82 gear in it. So far is way more efficient than the tci steel fighter that was in it. Lost 500 rpm at 65 than before
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 05-03-2016 at 11:13 AM. Reason: Link |
05-03-2016, 11:46 AM | #19 |
Nice. That should Rock N Roll
05-03-2016, 12:01 PM | #20 |
At the body shop.
Hope so, was doing 1.67-69 60' before. Worried I've hurt the 60' n/a but real curious how big of a shot it'll take out of the hole.
05-22-2016, 03:42 PM | #21 |
At the body shop.
Testing my patience.
Slip yoke was dripping, tried pulling the driveshaft out. Had to pry it off. Turns out I burned the tailshaft bushing up running it on the rack with rear off the truck up. And the drive line was too long, got that all fixed. And back to the tuning.
05-22-2016, 11:47 PM | #22 |
That photo of the sunset in your rear view mirror is GORGEOUS!! It has a lot of emotion and mood. You have a good photographic eye.
05-23-2016, 12:05 AM | #23 |
At the body shop.
Thank you.
Some of my recent favorites. Benicia bridge at night.
05-23-2016, 01:25 PM | #24 |
Very nice truck.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-23-2016, 02:50 PM | #25 |
I know the pieces fit
Are you running caltrac's? I can't remember what you're doing to make that thing hook. Congrats on getting it going again.
