Old 04-24-2016, 10:39 AM   #1
solidaxel
solidaxel's Avatar
New Code on the reader !
Well I think things are happening now that there are some miles on the engine & Trans.
Po742 showed up after a long drive, 50 miles?
TCC circuit "stuck" ??
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-24-2016, 11:33 AM   #2
ls1nova71
ls1nova71's Avatar
Re: New Code on the reader !
If the torque converter is actually stuck in lock up it will want to kill the engine when coming to a stop, like not pushing in the clutch on a manual. If it doesnt, you probably have a wiring problem and the PCM is setting the code because of it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-24-2016, 05:15 PM   #3
solidaxel
solidaxel's Avatar
Well it does have a surge when down shifting 3 to 2 and 2 to 1, especially when cold
LS 3 4L70E
Old 04-24-2016, 05:59 PM   #4
solidaxel
solidaxel's Avatar
Well I did check the cannon plug on the trans with a stock harness and the color code and location seems to be correct.
I guess I will have to prove it with two people and pin out the connector and the trans plug
Where else should I look for a wiring problem?
The brake light TCC plug checks out, brake on- tcc off
LS 3 4L70E
Old 04-24-2016, 06:22 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Since I love to blame tunes; if for some reason anyone played with your lockup settings, they can error out. Most of the time tuners shouldn't be touching your lockup settings unless they've had time with your setup in person (And most don't touch it at all).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2016, 06:27 PM   #6
solidaxel
solidaxel's Avatar
Wellll as a matter of fact!
Yes we did change the lock up settings and now I find that it is "searching" at a speed that is too low, 45MPH, and I am going have him put back to where it was before the tune I think lock up was at 55 MPH
LS 3 4L70E
Old 04-24-2016, 09:07 PM   #7
clinebarger
P0742...... The PCM commands TCC OFF, TCC slip RPM remains low (-20 to +20 RPM) This is not a electrical fault code.
There is no "Regulated Apply Oil" available in 1st gear...So the TCC will release upon a 2-1 downshift even if the TCC Solenoid is stuck on.
A Mechanically stuck/sticking TCC Enable Solenoid will cause this code.
The TCC Enable Solenoid is part of the internal trans wiring harness, Though you can splice in a new/good used solenoid using Red Insulated Butt Connectors to keep from pulling the 2nd Accumulator & EPC Solenoid to replace the harness.
While the Solenoid is out, Use an Awl too make sure the TCC Apply Valve is free (There is a hole in the retaining washer, Insert the Awl through the hole & stroke the Valve)
clinebarger is offline   Reply With Quote
Old 04-24-2016, 11:47 PM   #8
solidaxel
solidaxel's Avatar
Thanks Cline
Should I replace all the solenoids and harness while we are in there?
Any tricks I should know about?
LS 3 4L70E
Old 04-25-2016, 12:40 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cline, if thats the case, and one starts or suspects that the TCC is actually stuck on/locked, would manually putting the truck into 1 automatically unlock and act as proof-of-diagnosis?
Old 04-25-2016, 12:48 AM   #10
solidaxel
solidaxel's Avatar
I will do that in the A M
Then clear the code, and see if there is a difference?
LS 3 4L70E
Old 04-25-2016, 09:07 PM   #11
clinebarger
If the TCC is mechanically stuck (Very Rare), It wouldn't matter what range the trans is in. It would be locked all the time & stall the engine etc. Which is not a symptom the OP has.
But to directly answer your question about Manual 1st Gear, I'm not 100% sure, I would have to see what the TCC PWM Solenoid duty cycle is in Manual 1st. My hydraulic diagrams indicate that regulated apply oil is present in manual 1st. But the diagrams can be wrong.....Wouldn't be the first time.
What I do know is, The TCC cannot hydraulically apply in the OD/Drive range while the unit is in 1st gear, Because I have had the TCC Enable Solenoid or the TCC Apply Valve stick & the TCC would stay locked in 2nd, 3rd, 4th gear.
Well technically, It will unlock momentarily then PWM Apply right when its suppose to. Then under Decel, It will stay locked 'til the 2-1 downshift.
Hydraulic diagrams confirm this, Or should I say my experience confirms the diagrams are correct...
I was going to post the diagrams but photobucket SUCKS, Maybe later.
Old 04-25-2016, 09:09 PM   #12
clinebarger
Originally Posted by solidaxel View Post
Thanks Cline
Up to you....Your other solenoids are working.
Old 04-25-2016, 10:04 PM   #13
solidaxel
solidaxel's Avatar
I tried it in 1sr gear and everything seemed OK
I put another 30 miles on it today and it did not throw any codes
I will get the truck back in two weeks and try the TCC apply tricks you mentioned
Thanks all for your help
LS 3 4L70E
