09-27-2003, 11:22 PM | #1 |
What Do You Think It Is???
So I noticed a bit of a noise tonight coming from some where in the drive line - I think. It was a kinda "whirring" or "whining" noise. More noticable while coasting or breaking than accelerating. There was also a little vibration, but I'm not sure that this hasn't been there before.
I was thinking u-joints (rear one is fairly new), but there was no "clunking" when getting back on the gas. I have a split driveshaft and I know the carrier bearing housing (the rubber part) is kinda worn. I haven't been under the truck lately to check the drive line, and tonight I got home too late to really care - so I thought I'd ask the experts and then go look around when I get the time. Thanks. |
09-28-2003, 05:39 AM | #2 |
U-joint , definitly.
I had the same noise in my drive shaft , but most of the time , it was when I accelerated. Fix it before it breaks completely ( I've been there ! I thought it could wait a little , I went back home truckless , the rear part of that drive shaft was stuck between the bed and the RR axle... ) Really easy to check , crawl under your truck and check for loosening , you can even see it with the eye The Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
09-29-2003, 06:12 PM | #3 |
Thanks Baron,
I spent a little time under the truck yesterday (until it rained) . There was some slight movement in the front u-joint - not rotational movement, but I could move it up and down. Now it was difficult to tell if it was the u-joint moving or the shaft going into the back of the tranny, but I'm suspecting the u-joint. The rubber "housing" of the carrier bearing is getting looser as well. I can move it around quite a bit - I'd say a good 1/4" all around. I assume this is not normal either. Anyway, hopefully I'll get a chance to look at these things soon. Don't want to drop a drive shaft while flying down the road . |
10-01-2003, 12:00 AM | #4 |
Stylin
i had the original ujoints in my drive shaft for the longest then i decided to replace them after i couldnt stand the humming anymore. and a week later the caps go flying off goin down the interstate doing 80 sounds like ive got a flat or something so i pull over look at all 4's, rev it up in neutral then acts fine then i get back on and drive for about a mile then it starts vribrating again and i think what the hell, but to make a long story short, get some high quality ones.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
10-01-2003, 08:48 AM | #5 |
you lucked out, Christmas morning, i had a U-JOINT cap come of. i slammed on the brakes , due to that loud clunk, sent mr spinning in a donut in the middle of the road. glad it was early Christmas morning and there was no traffic. anyways, i ended up slidding down a ditch at about 70 mph and stopped abot 5 ft from a LARGE culvert. cracke the tranny case tail shaft and all the way around the bell housing. and they were new U-JOINTS. i will not use the U-JOINTS with the clips on the inside anymore, the ones that go on the outside at the end of the caps are the ones i use from now on.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
10-01-2003, 01:55 PM | #6 |
Thanks for all the horror stories guys
I certainly hope that I get a chance to do the work shortly. I've been out of town most of the last month and a half. So when I get home to stay tomorrow, I'll have to dig into it. My inlaws want me to haul some rock for them before winter comes (my Father-in-Law's truck is just a F150 )... so I better get this looked at before taking on some big loads. Thanks again |
