04-24-2016, 04:17 PM | #1 |
1972 K20
Rear end swap questions...WWYD?
I'm building a 67 c10 (with 49K miles) that has a 6 lug posi rear. I also have a complete 72 chassis to swap out mileage unknown. I have read up and searched converting 6 to 5 lug rear ends. Both rears have 3:73 gears, and I want the posi either way. So I have to either put the posi unit into the wider 72 rear or put aftermarket 5 hole axles in the shorter 67 rear. I think it would be less work to put axles in the 67 rear.
So my questions are: Would you use the 67 rear and why? Would you use the 72 rear and why? Are there fewer wheel backspacing options for the 67 over the 72? Can I just bolt in the posi carrier in the non posi rear and not have to reset the ring and pinion gears? I'm guessing I would have to re-shim for backlash but not have to change pinion depth... I plan on using the complete 72 disk 5 bolt front end. Thanks in advance for helping me decide what to do! |
04-24-2016, 04:39 PM | #2 |
Re: Rear end swap questions...WWYD?
I would use the 67 simply because I like the wider dish it allows you to have with the rear wheels. If cost is an issue the 72 would be cheaper since you wouldnt need to buy aftermarket axles.
Either way I would have it gone through/rebuilt, cleaned up, new bearings, seals, check things over good. |
04-24-2016, 04:40 PM | #3 |
The 71-72 (and late 70) rear is a little wider, want to say 1.5" to better match the wider front disc brake track.
If you swap the posi case you need to do a complete ring and gear reset. I for one don't even like transfering used gears but you never split a set. Might want to consider the rear brake condition too unless you are planning new from the backing plate out either way.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-24-2016 at 05:25 PM. |
04-24-2016, 05:11 PM | #4 | |
1972 K20
04-24-2016, 05:52 PM | #5 |
I thot the 67 axles were shorter than the 72 axles, hence axle and those housings are not interchangeable --may be wrong. So if you want 5 lug to match the 72 front disc --use the 72 axle --switch the posi.
I think the 72 axles will extend too far from the 67 housing/tubes.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
04-24-2016, 06:16 PM | #6 | |
1972 K20
04-24-2016, 06:28 PM | #7 |
oops -- I have redrilled also -- you have to drill or mill thru one partially welded hole as you know but can be overcome.
04-24-2016, 06:28 PM | #8 |
A wider axle (wms to wms) will allow a wider zero offset set wheel given the same suspension. In my book zero offset (or near to) is important on a semi-floating axle.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-24-2016, 06:30 PM | #9 |
Amazon.com: Motive Gear MG6569 8.875" Axle...These are what I used. Fit great and not much more than a set up kit. Plus you have to buy tools to change it over and come out at about the same price and have to do more work. Might spend an hour if you really take your time with the new axles. If you go with the 72 rear end you are using 44 year old axles so who knows what they have been through
04-24-2016, 06:59 PM | #10 |
1972 K20
dennislbrooks... no worries!
jdalexa84... Great price on new axles in a low mileage rear... have to think about that option. SS Tim...the constant battle between form and function! I won't be hauling anything in this truck...but I do like to drive at a brisk pace so good handling is not lost on me either. |
04-24-2016, 08:00 PM | #11 |
what wheels/tires are you planning on running?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
04-24-2016, 11:54 PM | #12 | |
1972 K20
I do like the salt flats or 338's depending on the costs? |
04-25-2016, 01:54 AM | #13 | |
to answer the question though, if it was me i would figure out the exact wheel/tire combo and figure out what axle width would work best. if it would help avoid a custom wheel backspace or rear end mods that seems like the best route to me. i like summit racing for the interface and ability to filter wheel specs to pin down options.
04-25-2016, 06:59 AM | #14 |
If needed - I have a pair of 5 on 5 - 1" wheel spacers with nuts that I will not use as my trucks are 6 or 8 or 4 3/4 x5 on the 42. I hope I am not scolded on the deadly sins of wheels spacers.
04-25-2016, 10:35 AM | #15 | |
1972 K20
04-25-2016, 04:49 PM | #16 |
all things being equal your best bet is to stick with what you have. a low mliage truck favors the origonal drive train too and the cost of simply switching everything over is not too cost effective. cheaper simply to buy the wheels you like in a six lug configureation.
