04-25-2016, 04:48 AM | #1 |
engine identification c20 1966
hi, i am not sure what kind of engine sits in my c20.
originally it was a 283ci ,i find the code WC on the sheet in the seat the engine has a rebuild plate with measurements. the manifold 3877652 is from 1965 and were use on 283/327. and i find these numbers on the engine... |
04-25-2016, 07:12 AM | #2 |
Re: engine identification c20 1966
04-25-2016, 09:20 AM | #3 |
F1118HC decodes as
F---Flint 1118--- November 18th HC--- Look here-- http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php The other number could be the rebuilders stamping. |
04-26-2016, 12:03 AM | #4 |
60-66 Nut
It's more than likely a 327, which is real good in my opinion. The block casting number will confirm that.
04-26-2016, 09:14 AM | #5 |
Do you mean the number on the driver side where the transmission ist mounted to the engine block?
04-26-2016, 09:53 AM | #6 |
05-08-2016, 05:07 PM | #7 |
i found 3782870 , looks i have a 327ci
05-09-2016, 02:22 PM | #8 |
head casting nr. 3795896
L263 |
05-10-2016, 12:59 AM | #9 |
60-66 Nut
Those are small combustion chamber and small valve 'Power Pak' heads.
http://www.mortec.com/castnum.htm
