I hate trannys
JW TH-400 ultrabell bellhousing for sale
I have a JW ultrabell bellhousing That somone reccomended I get after I broke two transmissions in half, soon after I bought it I found out that my flywheel was installed 180 degrees out so the vibration is what was breaking the trannys. I did try to install this and have a case that was cut that it bolted right up too, I hit a wall with the torque converter because I had a 12" one and because the bellhousing is a little thicker I would have had to buy an expensive smaller one and could not afford it. Then I tried to return it to the company and they said that I could not return it. So now im selling this and the case that is already cut if you want that too. Im asking $100 or will trade for parts that I need. It was mounted one time but is in perfect condition with mounting hardware.JW ultrabell
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do. |
Truck Farmer
Which tranny does it fit and what parts do you need.
Arizona rust free sheetmetal |
I hate trannys
it fits a TH-400. I need big block Power steering parts, and a rear and front sway bar. Im sure there is more that I can use but those are the things that I really want. Oh yeah and a hood.
Adam..does it come with the th400 case to? if so I will take it
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
How do you install a flexplate 180 off? There is a pin in the crank to keep you from doing that. At least that I rembember. . . .
I hate trannys
Well my crank didnt have the dowel? pin so thats how that happened. I found somone localy today that is going to trade me the th400 housing for a new tranny. hope you guys understand, thanks.
