Old 09-28-2003, 12:30 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need frame # help
The # on the frame under the steering hose's??? I was wonderin if some one could help me out I think I got a worth less 69-72???
The frame # is 2s144242 from what I could tell. The vin plate on the door say's CE149S849915. This truck is from O.K. and I am thinking some one swapped the frame out...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-28-2003, 06:13 PM   #2
Rod
Appears like it has been... the frames a 72 built in St Louis and the cabs a 69 built in St Louis.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-28-2003, 06:37 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thank's rod I called in the # on the police radio and it is not stolen so that make's me feel better I also called in the frame # and it is clean also..Thank's rod..
MEMBER #6377
Project "7DEUCE"
Old 09-28-2003, 07:29 PM   #4
Rod
You can pretty much patch together number for the police to check on from what on the frame... just add a ..in this a case sinces its a 72 frame go CCE142S14424 or CCS142S14424 or you could change the 4 to a 3 ... thats pretty much the only 3 it would be if its a 1/2 ton 2wd. If I saw the frame I could tell if it was an 8 or 6 originally and other stuff too... but thats from looking at lots...lol.
Old 09-28-2003, 07:30 PM   #5
Rod
HmmI guess it could have beena GMC frame too but it would of had a T in front and not the first C.
Cant think if they made GMC trucks in St. Louis right now. I have a good memory ...just short.
