Old 04-25-2016, 03:07 PM   #1
kray59
kray59's Avatar
Cool get in line
Thanks in advance for the advice . after a wreck , I am replacing the radiator support , inner and outer fender , grill and bumper . I have gathered all the parts and am ready to start to reassemble . my question is in what order should I put the parts on to make everything go as smooth as possible . thanks , kenny
This is MY rifle.There are many others like it but this one is MINE.
Beware the man who only owns 1 rifle , he probably knows how to use it.
kray59 is offline   Reply With Quote
Old 04-25-2016, 03:59 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: get in line
Have you had the frame checked yet?
Core support, outer finder, inner fender, hood, grille, bumper.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-25-2016, 06:09 PM   #3
hugger6933
Re: get in line
Use an X measurement to make things simple. Put on the core support, then find a common point on the right front[say the bolt hole that the fender triangle bolts to] and the cowl vent bolt on the left rear. Tape measure ti and get the number. Then go to the SAME points opposite side then read the tape.
The idea here is to get them as close as possible to the same number. That will mean the core support is Square to the cab that way the fender [and hood] will align MUCH better.
Then you can go about hanging the fenders then inners . Hood goes on then grille and bumper. If you get the measurement right on the fenders[X] you can bolt in the grille right after the fenders if you want it will be fine. that way if you have to wait on friends to help with the hood you can make progress until they show up.
hugger6933 is offline   Reply With Quote
Old 04-26-2016, 09:32 PM   #4
kray59
kray59's Avatar
Cool Re: get in line
67ChevyRedneck , i have not had the frame checked . are there any things in particular that i may be able to check myself ? thanks , kenny
Old 04-26-2016, 09:44 PM   #5
hugger6933
Re: get in line
Read my post. The X measurement can be used for anything, it is the MAIN way to check real fast if a frame is square or just the front or the bed anything you can figure on can use the X method to check it out. Like on the frame go against the crossmember on the drivers side then go to the frame horn on thew pass side. Read the tape then do opposite from the same spot and it will tell you if the frame is tweaked
Old 04-26-2016, 10:17 PM   #6
kray59
kray59's Avatar
hugger6933 , thanks for the info . i have read and printed to save for future referance . thanks again, kenny
