Freeze plug?????
My c10 has been leaking a fair amount of coolant but not while it is running or within a reasonable amount of time after engine is turned off. However, its not until the next morning that about a 1/2 cup of coolant is laying on the garage floor. So I jacked up the front end and the only place I could see a possible coolant leak was coming from the freeze plug(?) located (circled in red in pic) just above the starter on the passenger side of the engine block. I recently purchased truck so I don't have any history but it appears to be a fairly new plug. I hooked up a socket and tightened it a number of cranks and it seemed to stop leaking from its perimeter. I wasn't sure how tight to crank it. I had to leave the truck last night which is about 50 miles where I store it so I'm not sure if leak has stopped. Any thoughts if I'm on the right track here? Any suggestions? Is this plug the correct solution, or, is there a better or more effective option to consider?
1970 C-10 CST, LWB, 402/400, A/C |
Re: Freeze plug?????
That is not a freeze plug but it should be! i think that's an expansion plug, meaning a rubber donut surrounded by a couple washers and a bolt nut thru the center to make the rubber expand, I'd get it out asap and drive in a real freeze plug with proper sealant before it blows out under pressure, your asking for trouble by running it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Thanks Swamp Rat. I have never seen a plug like this so I was thinking it was some new invention. Will definetly replace ASAP. I have never replaced freeze plug before. Any advice? Buy replacement freeze plug from auto parts store, Chev dealer, other? What kind of sealant best to use?
![]() Join Date: Feb 2016
1 5/8" freeze plug from any auto parts store. They will all be selling Dorman brand plugs. Put a small smear of Permatex#2 around the edges and bang it in with a socket.
Thanks Shady R
Why would they use that? Freeze plugs are dirt cheap. I hope it's not hiding an unexpected problem....
A lot of people can't manage to hammer in a freeze plug straight if you held a gun to their head so they go the ghetto route, or they're just not aware of how easy it is to do correctly. I've seen the expanding plug deal done a lot of times over the years for lack of a 1.50 freeze plug and ten seconds with a hammer.
And, I've never seen one not leak in short order either. Half the time they wind up popping out under pressure. |
Up here it's an extra block heater plug. Haha. Seen 4 on a small block once
-Cody |
Go Pack Go!
Don't buy the cheap ones. Get a brass one.
#10 | |
if worse comes to worse. replace it with a block heater |
#11 | |
the bad news is that if one is going bad.....all the rest are too. including ones behind the motormount and the flywheel. might as well do them all and a clutch job too. |
#13 |
i's spend the extra time to completely check all the other freeze plugs to make sure they are all ok and not on the vergr of failure in the near future
#14 |
A previous owner probably had one fail (I have that happen once on a 350 when I was 12 hours from home) and the expansion style is much easier to install on the roadside or in a parking lot, that sort of thing.
Particularly if you don't have the space to get a big socket and hammer in there where the engine happens to be sitting.
#15 |
Be careful over tightening those. Have seen them pop out that way. I would almost bet the PO just drove the failed plug into the block instead of removing it. And I would not sweat getting a brass one. Steel will be fine for decades in a properly maintained cooling system running modern anti-freeze.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() Last edited by GRX; 04-27-2016 at 02:21 PM. |
#16 |
Thx, all really good comments. Will try to attack the replacement tomorrow.
