Old 04-25-2016, 08:53 PM   #1
72freak
Rottenwood Garage Member
72freak's Avatar
Removing cab AND front clip at at once. Has anyone done it?
I'm only looking for factual input from those who have tried it...NO OPINIONS PLEASE.. I have removed MANY cabs, beds and front clips but I have NEVER tried to remove a cab with the front clip minus hood attached to it. I will be using a 2 post lift probably supporting ONLY the cab with the lift and the front clip with 2 men. The weight of the fenders, inners, grille and support is not that much but will it put unnecessary strain on the mounting points of the clip to the body? I am planning of lifting, rolling the old frame out, rolling the new frame in and setting it down.
Has anyone tried it?
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 04-25-2016, 09:15 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Removing cab AND front clip at at once. Has anyone done it?
My body guy did this but in reverse, he put the front clip & cab onto my chassis in this manor !
As you can see in the picture he suported the front clip with the lift also, this way there was no undue stress, eveything was suported evenly ! Hope this helps !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-25-2016, 09:49 PM   #3
Todd Hepler
Todd Hepler's Avatar
I did it with a chain fall, 4 straps, and one person.
Shouldn't be too hard to figure out with 4-6 people.
Race dually
T
Todd Hepler is offline   Reply With Quote
Old 04-25-2016, 10:04 PM   #4
72freak
72freak's Avatar
Race dually
T
Rottenwood Garage Lifestyle! Race diesel dually
Old 04-25-2016, 10:23 PM   #5
hugger6933
I have not done it with this body style but the newer ones with the back arms on the rockers and the front ones on the fenders. I even did one once that I didn't break the a/c lines and kept the Freon charge. You most certainly can do that front and cab together. Jim
hugger6933 is offline   Reply With Quote
Old 04-27-2016, 12:25 AM   #6
mike16
yep. and all by my self. stripped the cab to the point where it was light enough to simply roll off the frame to one side. neighbors came out to watch, only one came out to help. and all he did was film me doing it befor he helped. go figure.
mike16 is offline   Reply With Quote
Old 04-27-2016, 12:30 AM   #7
El Dorado Jim
I have done it with a square body truck, using nylon straps and my tractor
El Dorado Jim is offline   Reply With Quote
Old 04-27-2016, 06:13 AM   #8
Yes, I have and it goes smooth as cream. Saves a lot of time.
Old 04-27-2016, 08:25 AM   #9
72freak
72freak's Avatar
Thanks for the input! Its on for Saturday. Going to try to squeeze it around a Cummins/5 speed/transfercase.
Old 04-28-2016, 10:33 PM   #10
72freak
72freak's Avatar
Doing stuff!
Old 04-30-2016, 06:40 PM   #11
72freak
72freak's Avatar
Thanks for the input guys. Transition complete
Old 05-01-2016, 07:49 AM   #12
notsolo
notsolo's Avatar
Wow, you have made quick work of that! Awesome. Did you have any support under the front end when you lifted it? Or just the 4 points under the cab.
notsolo is offline   Reply With Quote
Old 05-01-2016, 12:31 PM   #13
72freak
72freak's Avatar
I had 2 guys up front when we removed it BUT it was not needed because we left the inner fenders in it. I did later remove the passenger side inner fender and you could tell it gave a little but at that point we were setting it down on the Dodge frame and we supported it immediately with cut to length pieced of 4x4's/.
Old 07-21-2016, 06:45 AM   #14
72freak
72freak's Avatar
It is mobile!
https://www.youtube.com/watch?v=JqUw3qHkoi0
Old 07-21-2016, 06:52 AM   #15
GR8-68
GR8-68's Avatar
This is one sweet build, excited to see the end results
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
