Old 04-26-2016, 10:39 AM   #1
canadian_diesel1964
Metric Steering Box..more questions...anyone adapted?
Hey guys I have searched and searched..found 30 answers but not sure which is correct..i know a while back someone posted a pic of the metric to flare adapters to connect the metric box out of an 86 C10 to the flared lines..i could not find it and I apologise..any info is appreciated and i know LEE manufacturing is out of business so I guess they are a no go..thanks in advance..I was also wondering for those who have done it do you have enough room...
canadian_diesel1964 is offline   Reply With Quote
Old 04-26-2016, 11:20 AM   #2
frankslagoon
Re: Metric Steering Box..more questions...anyone adapted?
I used a 89 gear box. I just changed the fitting in the back of the pump to the new style and used the lines from the 89 .
frankslagoon is offline   Reply With Quote
Old 04-26-2016, 11:30 AM   #3
60chevyjim
60chevyjim's Avatar
on my 93GMC with a 1975 454 I put in it
I cut the metal part of the high pressure lines from the box and the pump and used a union and 2 fittings by flaring the end of both of the high pressure lines after putting the fittings on to connect the two different lines together with the union on the high pressure line . I had both sets of hoses Oring from the box and flare from the 454 pump
the low pressure line just uses a hose clamp on the hose so if you have the fitting from the box with the Oring that one is ez to do.
or you can use google to find the adaptors your looking for .
60chevyjim is offline   Reply With Quote
Old 04-26-2016, 11:38 AM   #4
frankslagoon
I tried the flare deal and had a heck of a time getten it to seal. I guess I'm not to good with flare fittings. But it's so easy to go to the junk yard and get a o-ring style pump fitting out of a core pump and screw it in to the old pump on the trk.
Old 04-26-2016, 11:50 AM   #5
canadian_diesel1964
Thanx guys good ideas..ive tried google i must be putting wrong info in...
Old 04-26-2016, 12:02 PM   #6
padresag
did you try searching on here. believe it has been brought up within the last 2 weeks
ron
padresag is offline   Reply With Quote
Old 04-26-2016, 12:26 PM   #7
canadian_diesel1964
hey ron I did try the search but couldnt find it...now me being me i took a screen shot of that page lol and found it...
Borgeson 923122GM o ring adapter set!..thanx guys
Old 04-26-2016, 01:05 PM   #8
61K10
61K10's Avatar
CPP has them also-----o-ring to inverted flair.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-26-2016, 01:12 PM   #9
padresag
you are trying to use an 86 steering box with the earlier pump; am I correct. the easier way is to use the metric hoses and change it at the pump. if you have the 86 pump; where the pressure hose connects to the pump, there is a large nut. back that out with what is attached to it and put it in the earlier pump. it is pipe thread where that goes in and they are interchangeable
this seems to come up regulary.
ron
Old 04-26-2016, 02:37 PM   #10
canadian_diesel1964
I just have to get the newer metric size fitting for the pump I guess...and those CPP things look good too! thanx guys
Old 04-26-2016, 03:51 PM   #11
frankslagoon
ron
I tried to explain that also but I quess he wants to order adapters I hope he has enough room behind the pump .
Old 04-26-2016, 05:09 PM   #12
canadian_diesel1964
I got ya and thank you...I think id prefer to change to the inserts on the gear as all my hoses are new as is the old style pump(i may try and find a newer one with hoses etc also)...the borgeson parts look stock and wont take any room up at all...I really appreciate your input..sometimes at work here its hard to get a clear thought out..I now have 2 ways to go on this ...
Old 04-26-2016, 10:06 PM   #13
61K10
61K10's Avatar
for people that are reading this post--post what you have to work with or if you have nothing. It makes a big difference when trying to help.
1961 chevy K10
Old 04-27-2016, 01:12 PM   #14
canadian_diesel1964
Sorry about that
Old 04-27-2016, 01:20 PM   #15
frankslagoon
I didn't realize ya already had the hoses for the old pump. sounds like a good plan.
