Old 04-26-2016, 09:28 PM   #1
eugrides
radiator fan location
I have a 53 GMC 1/2 TON with a stock crate 350 and a new champion rad with 1 1/2 in. bottom and top hose connection I want to know the best distance from mechanical fan to rad and do I need a shroud .probably use a 18 in. 6 blade fan any advice appreciated Thanks
eugrides is offline   Reply With Quote
Old 04-27-2016, 12:09 PM   #2
_Ogre
_Ogre's Avatar
Re: radiator fan location
do I need a shroud
yes you need a shroud to properly pull the air thru the radiator with any fan
distance away does not matter as long as the shroud covers the fan blades
this is a factory v8 shroud for my 59 panel
shop air compressor timer
Old 04-27-2016, 12:27 PM   #3
eugrides
