04-27-2016, 11:13 AM | #1 |
Please help-Fan spacer not coming off
So I went to install my shroud, removed the bolts and the fan but the spacer is stuck on, to my knowledge there are no bolts holding it on and I could not find any, before I go to the rubber mallet does anybody think I need a puller or something? The spacers sell as an individual unit so I am perplexed, thank all! Pic below:
Here is the spacer I think I have: http://www.northernautoparts.com/Pro...ProductId=3178 Forgot to mention, shroud will not go in with the spacer there. Last edited by ubtripn; 04-27-2016 at 11:26 AM. |
04-27-2016, 11:30 AM | #2 |
Re: Please help-Fan spacer not coming off
Just hit it........hard.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
04-27-2016, 11:30 AM | #3 |
No bolts on any spacer I have ever seen. give it a wack
04-27-2016, 11:35 AM | #4 |
Nothing should be holding the spacer in seems to be a little froze up give it light taps , I'd use a light ball peen hammer flat side , be real careful when it breaks free it don't going crashing into you radiator .
NGN Nick Last edited by NGN; 04-27-2016 at 11:41 AM. |
04-27-2016, 12:12 PM | #5 |
On it, thanks all!
04-27-2016, 12:31 PM | #6 |
Rubber hammer, but watch the rad fins on the backswing and followthrough!
04-27-2016, 12:36 PM | #7 |
Yeah I have a thin piece of plywood I insert while doing this type of thing, its why my radiator is new now =)
04-27-2016, 12:43 PM | #8 |
As others have said, just hit it. The nose of the water pump shaft is just seated into the spacer a tad.
04-27-2016, 03:24 PM | #9 |
20' Daredevil (Ret)
I didn't think clutch fans used spacers....
04-27-2016, 04:41 PM | #10 |
Yeah Stocker, I was thinking same thing. I've never seen a spacer with a clutch fan, but it might be that he's running a short nosed water pump, or smaller shroud. I'd see if the fan fits the shroud better without a spacer. The blades don't have to be all the way inside the shroud. they actually flow more air if about half the blade is exposed outside the shroud edge.
1970 GMC Stepside Short Gone...Factory 350 V8 Now...4.8L LS |
