Old 04-27-2016, 12:19 PM   #1
suburban99
suburban99's Avatar
1962 window weatherstriping question
Hey all, I need to order some weatherstrip for the doors on my 62. The websites all say the weatherstrip is for non-framed glass. I believe mine in framed glass. Any idea where to get it? Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-27-2016, 01:04 PM   #2
davbowen
davbowen's Avatar
Re: 1962 window weatherstriping question
lmc truck has a whole kit p/n 38-5993.
davbowen is offline   Reply With Quote
Old 04-27-2016, 04:23 PM   #3
par4tom
I agree with regards to the channel felt...the LMC product was a Made in the USA product and worked perfectly. The door weather stripping is another matter...
With no disrespect to any LMC fans, I would not recommend LMC or any of the other "Supply Stores" that use the standard imported product for the rubber stripping inside the door jamb. I too had LMC, put it in and the doors would not shut anymore. It looked the same, but the doors wouldn't shut.
I asked here on-line for some advice (same as you) and some of the guys recommended Sof-Seal. I called Sof-Seal and they said the nature of their weatherstripping is softer...more like the original materials back when these trucks were built. Even though the LMC stuff profile will look to be the same...I can assure you that it is not. Ask me how I know...
I have Sof-Seal, and highly recommend them. I also recommend that before you go too far (in case you haven't painted yet), make sure the lip that holds the stripping, is evenly spaced away from the door so that the molding doesn't get too pinched...
Get in the truck, close the door and see if you can get about 1/2" spacing...especially along the bottom of the door between the lip and the door facing.
As far as your windows go, you can pull the frames off the glass and get replacement felt liner at just about any glass shop. I pulled mine apart, took the frames to get powder coated and then had the glass shop reassemble everything for the door glass. I watched them do it and I think I could have done it myself...
You have a nice looking truck there!!!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 04-27-2016, 04:49 PM   #4
Bullett
Geesh, as the saying goes, you learn something new everyday. I had never seen framed glass before nor hadn't heard about it. Looks very cool, old Skool cool.
Bullett is offline   Reply With Quote
Old 04-27-2016, 05:39 PM   #5
suburban99
suburban99's Avatar
Just looking for the window weatherstripping right now. I already used the honda van rubber for the doors from the auto wrecker...works excellent rubber is soft...Thanks for the LMC comments...
2015 Ram 4x4 1500
1997 Boxster.
Old 04-27-2016, 05:40 PM   #6
suburban99
suburban99's Avatar
Actually the only one I have seen with it as well. (not that there's lots of them up here...)
2015 Ram 4x4 1500
1997 Boxster.
