04-28-2016, 08:09 AM | #1 |
Booster/Master cylinder ?
I'm in need of a new booster/master cylinder set-up and I'm considering this one......8" dual diaphragm
http://www.ebay.com/itm/1967-1972-ch...0372#vi-ilComp I will be doing an LS swap in the future so I don't want to go hydroboost right now.....just need to refresh the brakes...... Anyone have any experience with this set up?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-28-2016, 08:28 AM | #2 |
Re: Booster/Master cylinder ?
It looks like the one I used but mine had no prop valve. One thing to check is if it has a residual valve for the rear drums. Since it is sold as a disc/drum setup, it should. But if not, residual valve can available and can be installed inline low and out of sight.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-28-2016, 09:11 AM | #3 |
What calipers are you using? I bought the exact setup for my build (9" booster) and I couldn't use the master. The 1"bore was too small, but the big problem with the Corvette style master is the lack of stroke. They only have 1 1/8" which doesn't give you much volume, and it would bottom out way before the pedal reached the floor.
I had to use (reluctantly) an OEM 1 1/4" dia bore for my twin piston calipers. The good part is that the OEM master has 1 7/8" of stroke. Be very careful when choosing your master because each application is different. |
04-28-2016, 11:25 AM | #4 |
I assume these are the stock calipers.......I haven't pulled anything apart yet but AFIK the front was converted to disc since this is a '70 model....It could be a "late" '70 that had disc from the factory....IDK?
I'm going to pull the wheels off and check it out before I pull the trigger on new set-up
04-28-2016, 12:15 PM | #5 | |
04-28-2016, 09:02 PM | #6 |
I'll find out soon enough.......got one on the way......looking for some good quality drilled & slotted rotors now...any suggestions?
