Old 09-28-2003, 10:04 AM   #1
Luv68's
Luv68's's Avatar
Question 1/2t vs. 3/4t fenders
Are the fenders from a 1/2 t the same as a 3/4 or 1 ton? I have a chance to get a couple of fenders but the guy told me they wont work on 1/2 ton
Luv68's is offline   Reply With Quote
Old 09-28-2003, 11:42 AM   #2
crazy longhorn
Fabricate till you "puke"
10-30 series are the same(1/2 ton thru 1 ton), assming they are the proper set of yrs. On the chev, 67 & 68 will interchange, but the 67 has no sidemarkers. 69-72 will all interchange.....th onl difference on them is the grill on the truck. I havent been into the GMC's, so I cant help with that. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-28-2003, 11:51 AM   #3
1971 Cheyenne
1971 Cheyenne's Avatar
68-72 GMC fenders are the same as the 68 chevy fenders! The 67 GMC fenders are the same as the 67 chevy fenders. They are identical to the 68-72 GMC fenders and the 68 Chevy fenders with the exception that neither of the 67's have marker light holes.
That is probably really confusing, but in short, unless it will not interchange because of your year, it will fit. The fenders are the same for all 1/2 t 3/4t and 1t.
Assuming that you have a 67, (your signature), you can use fenders from either a 67 chevy, or a 67 GMC and they will be correct. You can also use fenders from a 68 chevy, or a 68-71 GMC and they will fit, but you will have a marker light hole, shich did not come stock on your truck.
I know I know, more confusing! Reply if you still have questions!
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 10-01-2003, 07:39 PM   #4
Luv68's
Luv68's's Avatar
thanks for the info, appreciate the response this really helps
