Old 04-28-2016, 09:28 PM   #1
JointTech
JointTech's Avatar
Upper control arm shims now?
I noticed I have a bunch of negative camber after putting my suspension parts back on the frame after painting.
Then I realized I didnt put any of the shims back on the upper control arms.
Since the cab and fenders are still off and its easy to get to should I put some in and eyeball it or just wait and let the alignment shop deal with it when I get everything buttoned up?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-28-2016, 09:55 PM   #2
hugger6933
Re: Upper control arm shims now?
Go ahead and put some in
hugger6933 is offline   Reply With Quote
Old 04-29-2016, 09:46 AM   #3
68 P.O.S.
See this thread from BMERDOC: http://67-72chevytrucks.com/vboard/s...d.php?t=487363
Let the shop deal with the shims.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-29-2016, 05:30 PM   #4
Davidf
Mine was shimmed so far out before rebuild that the nut did not grab all the threads on the stud. Turns out this was due to compensating for a broken spring. I put a few shims in to get it close, then let the shop deal with it.
Davidf is offline   Reply With Quote
