Old 04-28-2016, 10:34 PM   #1
Willie Makeit
Willie Makeit's Avatar
Wideband: What are you guys using with HPT?
wanted to ask what you FI guys were using for widebands with HPT and why that particular brand/type?
give me pro's and cons. new to this side of the game but wanting to learn.
let's hear it.
thanks!
Willie Makeit is offline   Reply With Quote
Old 04-29-2016, 01:10 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wideband: What are you guys using with HPT?
I run an Autometer for onboard monitoring and general logs. HPT doesn't list its transfer protocol but an AEM protocol can be modified to make it work. Its accurate enough to be safe, but its not dead-nuts when compared 1v1 to more expensive units.
Innovates are $$ but very nice. Instead of using the HP Pro onboard logging, you use the Innovate logworks and sync and import your 02 logs against the tune. EXTREMELY accurate, its what we use for dyno tunes and our personal car street tunes.
AEM's are pretty good, though I've only run them as a gauge and not logged off of them. HPt supports transfer for AEM and Innovate directly. Bosch and Autometers can also be run with the modified transfer protocol.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-29-2016, 09:19 AM   #3
StingRay
StingRay's Avatar
I've just started getting into this. I have an Innovate LC-2. I was just reading up and learning what I could with 2.24. There is a ton of good info out there to learn 2.24. 3.0 came out and I'm struggling.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-29-2016, 12:45 PM   #4
akdg87
akdg87's Avatar
im running the AEM Uego with my setup. i dont have the pro version of hp tuners and am logging afr through the A/C pressure sensor port. Pretty easy to do and makes tuning a hell of a lot easier, mine is permanently hardwired.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 04-29-2016, 10:31 PM   #5
solidaxel
solidaxel's Avatar
A/C pressure port ???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-30-2016, 01:14 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its an open input PID on the ECM. Its one of a few existing PID's that can be modified to monitor systems other than their intended target (depending on which ECM you have, and what equipment is being retained). If your not running A/C, then the A/C pressure port is an open channel.
So long as the channel being used is able to transmit the type of data you want, then that channel can be set to a custom function and relabeled to log or display that data on a gauge. (However that channel could not do something like control an injector, since it doesn't have any interface with the injector drivers.)
Old 04-30-2016, 12:47 PM   #7
solidaxel
solidaxel's Avatar
Thanks........................................I knew that, JK
LS 3 4L70E
Old 05-01-2016, 10:29 PM   #8
Willie Makeit
thanks fellers. currently leaning towards the PLX DM-6 SM-AFR (link below) - no gage, HPT interface datalogging only.
Any negatives or positives you guys know about and care to share?
Def gonna give the Innovate LC-2 a harder look. Price wise it's a wash.
thanks!
http://www.ebay.com/itm/171569130252...%3AMEBIDX%3AIT
Old 05-02-2016, 12:11 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
That says its using the Bosch sensor, which is a decent one to have. Only a few companies actually make the sensors. Bosch is fairly common and the sensor itself is reliable and less expensive to replace (they do go bad just like a normal car o2).
There are a few cheaper widebands that use one of the Chinese-brand sensors, which don't have a common-style plug and can't be replaced as easily.
IIRC, Innovate sources a different sensor that is arguable the highest quality. The sensors in most of their products are certified for on-road and government standard testing equivalents. Does this matter to you? Probably not, but if for some reason it does, then they are "the" option.
Were you using the Hp Pro, or logging through an external device or Ngauge?
Old 05-02-2016, 12:30 AM   #10
Willie Makeit
Both plx and innovates (at least the LC2 model) use the same Bosch LSU 4.9 sensor.
I will be using HPT Pro.
Old 05-02-2016, 09:15 AM   #11
solidaxel
solidaxel's Avatar
I asked my tuner about it, and here is what he had to say
I have one of those and it's lasted longer than an AEM or Innovate I had before.
Jim
LS 3 4L70E
Old 05-02-2016, 11:31 AM   #12
Willie Makeit
Jim
one of those? the plx?
thanks!
Old 05-02-2016, 12:43 PM   #13
Wasted Income
Boosted Member
Wasted Income's Avatar
Back in the day I used to run an Innovate LC1....total piece of garbage...used to lose it's cal info on occasion among other problems.
Then I moved to an Innovate LM1. Worked pretty decent...much better than the LC1.
On my megasquirt setup, I used the AEM UEGO to feedback wideband data realtime to the ecu. Never had a single problem with it.
The AEM is what I'd suggest. Pretty inexpensive too.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-02-2016, 01:49 PM   #14
Custom 68
Custom 68's Avatar
I use the AEM UEGO as well. I do like it. I too would suggest it.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-02-2016, 02:10 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
On Innovate's reference page, they have a paragraph about "not using the Bosch calibration resistor"....so it does sound like the Bosch sensor, but apparently not wired/setup "normally". I have more questions than answers about that.
If your using pro, then ya you should have the (6-wire?) interface on the side of the box. You should be able to use pretty much any wideband so long as it uses the normal wiring.
I've used the LM's and the MTX, and they worked nicely. I didn't own them so I can really comment on value for $ on those.
Old 05-02-2016, 07:03 PM   #16
solidaxel
solidaxel's Avatar
thanks!
Gen 4 PLX, sorry !
LS 3 4L70E
Old 05-03-2016, 12:41 PM   #17
boostedc10
boostedc10's Avatar
I had a ton of issues in my last build with the LC-1, spent more time chasing a moving target with voltage offsets than actually using it for what it was for. I swapped to a newer LC-2 and it was much better. I am with Wasted though, the AEM UEGO never gave me any problems.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 05-15-2016, 12:21 PM   #18
Willie Makeit
Thanks for all the input guys. Also talked with a friend who tunes for a living and based on his advice I pulled the trigger on the Innovative Motorsports LC-2.
Amazon.com: Innovate Motorsports (3877) LC-2... Amazon.com: Innovate Motorsports (3877) LC-2...
Will report back once i get my feet wet.
