04-28-2016, 11:15 PM | #1 |
Custom Truck Lover!
Factory steering wheel on after market tilt column, HELP!
I want to run my factory steering wheel on an after market tilt column. Does anyone make an adapter? Has anyone figured out a trick for this? Thank you.
Squarebody guy |
04-29-2016, 12:00 AM | #2 |
It's Better With Nitro
Re: Factory steering wheel on after market tilt column, HELP!
It depends on which column you're going to use. The Ididit retro tilt column for the mid-year GM trucks use the same spline as the GM steering wheels. I'm running an Ididit tilt column with the original steering wheel.
04-29-2016, 12:52 AM | #3 |
i got a tilt from KevsClassics i am using my original 66 wheel
04-29-2016, 05:33 AM | #4 |
Factory wheel should bolt up fine, but the horn connections, turn-signal canceling cam is not going to function correctly due to the big configuration differences.
04-29-2016, 10:27 AM | #5 |
Custom Truck Lover!
Thank you. So what are you all doing for a horn? Is it on the floor?
Squarebody guy |
04-29-2016, 10:50 PM | #6 | |
You can see it in my build thread. I still have mine connected because of a bad horn kit, but I have a horn button on the dash under the headlight wiper switches. You can get them in most autoparts in the general accessories section.
