04-29-2016, 10:25 AM | #1 |
Headlight ??
Both my headlights aren't working on lo beam they come on if I hit hi beam. I checked the connection and neither is getting power on lo beam. Is my headlight switch going out or what? Thanks for the help
04-29-2016, 10:27 AM | #2 |
20' Daredevil (Ret)
Re: Headlight ??
Check the dimmer switch & connections to it -- common problem area.
04-29-2016, 10:34 AM | #3 |
Re: Headlight ??
Everything is connected I am at a loss. I keep wondering about the switch
04-29-2016, 11:26 AM | #4 |
Re: Headlight ??
check the dimmer switch connections for corrosion and broken wites don't just glance at it take things apart to get down on it and really look and inspect it
04-29-2016, 11:34 AM | #5 |
Re: Headlight ??
Will do thanks for the help guys
04-29-2016, 12:04 PM | #6 |
Re: Headlight ??
Sometimes we take for granted the simple,overlooked things that really bite you hard if you don't scrutinize them from the word go...I once bought a 1986 Iroc-Z Camaro with a TPI 305 from a fellow that gave up troubleshooting it because the right bank of injectors wasn't firing, and he swore the fuses were good to both banks of injectors, $750.00 later and a .25 cent fuse and I was motoring down the road....moral of the story, never take things for face value, always check fuses with an ohm meter and everything else with a microscope..... The stupid things will get us every time....been there many times, just different situations.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
04-29-2016, 03:23 PM | #7 |
Re: Headlight ??
Knowing how to test all different parts of your vehicles operational system will save you huge money down the road, that's the issue with allot of knew mechanics today, no one wants to trouble shoot and test things, it's just a list of issues and possible parts to replace that might fix the problem, replacing things until the issue is fixed is a costly way to operate.
1972 C10 - It might be old, but it's not slow |
04-29-2016, 04:07 PM | #8 |
Msgt USAF Ret
Re: Headlight ??
Pull the dimmer switch connector and jump between the blue and tan wires with the headlight switch on. If the lights don't come on the tan wire is open to the lights or the bulb low filaments are blown.
If they come on then the dimmer is bad.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
