09-28-2003, 11:52 AM | #1 |
Can you ID this rear-
The rear end in my 69 is starting to get noisy and clanky at take off. As I call around to get rebuild estimates how do I refer to it. Do I just call it a 12 bolt Chevy? Can this be built into a posi rear end? Or is there something else I could bolt in instead of rebuilding this one. I am also considering adding disc brakes while I'm at it.
Thanks in advance as I am totally ignorant when it comes to rear end work. Dennis |
09-28-2003, 11:57 AM | #2 |
Yes, that is just a corporate 12 bolt rear end. You can have a posi installed (what i'm doing). GMC Pauls sells a disc brake kit for this rearend.
12 bolts are known to be a very good rear end and I would definately have it rebuilt before going and getting another.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
09-28-2003, 12:37 PM | #3 |
REAR ID
WHEN YOU TALK TO SOMEONE ABOUT REAR JUST TELL THEM YOU HAVE 8.875 12 BOLT TRUCK REAR END AND YES A POSI CAN BE INSTALLED I JUST GOT MINE ALL DONE BUT YOU NEED TO FIGURE OUT WHAT GEAR RATIO BECAUSE IT DICTIATAES WHAT CARRIER FOR POSI SERIES 3 OR 4 I THINK 4'S IS 3.73'S OR LOWER IE 4.11 OR 3 FOR ANYTHING HIGHER THAN 3.73 IE 3.08'S HOPE THIS HELPS ALSO KEEP IN MIND AUBURN POSIS ARE NOT REBUILDIBLE EATONS ARE AT LEAST THATS MY UNDERSTANDING ABOUT +/- BETWEEN THE 2
09-28-2003, 12:49 PM | #4 |
Isn't there a series of letters /numbers stamped on the top right side of those rearends to tell what they are? Should say something like HM,MH--3.36 POSI,HC,TU,HN,MJ---3.73 POSI, JQ,TV,HO,HP,MK,MI--4.11 POSI......
09-28-2003, 01:34 PM | #5 |
1FINE69
Rear end
Good luck withit. I just dropped $900 to get my 69s 3.07 12 bolt redone this spring. Was toying with going posi but decided since its a daily driver in snowy conditions its wasn't worth adding another $400-500 to get a little more traction. JM.02s
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
