Custom Truck Lover!
1964 C10 Door panel screws
A few questions
1. Does anyone know exactly what screw to use? Size and length? 2. Is there a clip or something that holds the handles on the door handle/lock and window crank? What keeps them from falling off? 3. Do I kneed to buy gasket material for the door panel or just bolt it up? I am assuming it will rattle? 4. Has anyone found a cheaper place to buy the door window channel set? LMC is $80. Thanks
Squarebody guy Last edited by YOLO; 04-29-2016 at 06:19 PM. Reason: added more questions |
Re: 1964 C10 Door panel screws
Answer to #2...set screws with a flat blade screwdriver
#3 | |
meowMEOWmeowMEOW
2. They are on a spline and held with a set screw. If you take them on and off a bunch, go get a small allen set screw instead...it won't strip nearly as often. The pot metal handles can get sloppy if they are worn out, you can use epoxy or putty to build the gap up for a more solid fit. There is also a little cardboard washer and "gasket" that goes behind the handle it to take up the gap. 3. I've never bought the stuff that LMC sells for inside the door panels (like a thin low density foam. Instead I use 3m seam sealer tape for any chaffe areas to prevent vibration (including doors, fenders, exposed stuff). 4. no clue.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
Custom Truck Lover!
Squarebody guy |
Chevy addict
Door panel screws and handle washers are available from Classic Truck Parts and look real close to correct.
#6 | |
meowMEOWmeowMEOW
